Suspension lift question
Discussion in 'Suspension' started by 4x4.StatlerTaco.XVI, May 11, 2021.
  1. May 11, 2021 at 12:05 PM
    4x4.StatlerTaco.XVI
    4x4.StatlerTaco.XVI [OP] Well-Known Member
    Los Angeles
    Hello. I recently purchased a used 2016 Tacoma 4x4 OR short bed with 265/75/16 tires on it.
    I’ve done a bit of digging on TW but I’m beginning to get confused. I want a 3 inch lift in the front and want to level the rear (which I think would be 2 inch in the rear??).
    I don’t want blocks or spacers. Very rarely do I carry anything more a couple heavy things in the bed (help friends with moving things once in a blue moon). Very rarely do I go off-road (I hit dirt maybe once every three months if that). So I know I don’t need anything with reservoirs but I do want to keep the ride quality (I know there’s a bit of a trade off here).
    So from reading along, I was thinking coil overs (I think that’s what you call strut and springs together) in the front (maybe the 6112 bilstein or eibach brand). Looks like I’ll need UCA’s and new rear struts as well. Im still debating on AAL or a new leaf pack all together. And add new bushings as someone on here suggested.
    I would like a buy once cry once kit since I wouldn’t really know how to piece everything together. Also Way down the line I will be adding 285’s/33” tires. Am I missing something here? And are there any suggestions? Thanks.
  2. May 11, 2021 at 2:00 PM
    CruJones33
    CruJones33 Well-Known Member
    2020 TRD OR
    My situation is very similar.. Here's what I'm doing:
    Bilstein 5160/6112 Combo (Set at the 6th notch with 1/4 shim to correct lean)
    Deaver Expedition full leaf pack - Stage 1 (0-300lb bed weight)
    71tattooguy likes this.
  3. May 11, 2021 at 3:13 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    6112’s / 5160’s here as well. Stoked on set up. Let me know how you like the stage 1. Thinking about doing that eventually. AAL is working for now. When does it stop!! LOL!! :thumbsup:
  4. May 11, 2021 at 3:14 PM
    CruJones33
    2020 TRD OR
    What notches did you do? UCA's? Did you get the truck to align?
  5. May 11, 2021 at 3:15 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    OP UCA’s just do it when you do everything. Include ECG’s bushing as well. While you have front end apart. Uppers IMO are needed for a good alignment and driving.
    Mmaira2018 likes this.
  6. May 11, 2021 at 3:15 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I did 6/5 no lean spacer and aal in rear
  7. May 11, 2021 at 3:17 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    3” is too much. Lower that get better performance and reliability and put the savings in a better kit.
    opinion
  8. May 11, 2021 at 3:36 PM
    CruJones33
    2020 TRD OR
    I'm going 6/6 notch with a 1/4 shim for a full 2.5 up front. Deaver expedition full 2" pack in the rear. We'll see on alignment & possible UCA's etc.
  9. May 11, 2021 at 3:45 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    UCA’s are going to be needed just saying. I said the same thing before I got mine :thumbsup:
  10. May 12, 2021 at 9:21 AM
    4x4.StatlerTaco.XVI
    Los Angeles
    You mention a lean. Are you referring to the lean that comes from the one side of the truck that is heavier? I am imagining a side to side lean instead of a forward to back lean. If so how and with what do you correct that with?
  11. May 12, 2021 at 9:24 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Set your 6112’s at 6/5 and your good. Unless you want to add for extra lift. I would stay at What Bilstein suggests that’s me. Good luck
  12. May 12, 2021 at 9:31 AM
    4x4.StatlerTaco.XVI
    Los Angeles
    What do you suggest would be a good lift height that would get me better performance and reliability?
    or is it the notch placement that I would need to lower?
  13. May 12, 2021 at 9:32 AM
    CruJones33
    2020 TRD OR
    You correct it with notch placement on the front. 6 on one notch and 5 on the other.
  14. May 12, 2021 at 9:36 AM
    4x4.StatlerTaco.XVI
    Los Angeles
    Oh ok I see what you mean.
  15. May 12, 2021 at 9:38 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Isn’t that what I said :thumbsup: Your welcome
  16. May 12, 2021 at 10:06 AM
    CruJones33
    2020 TRD OR
    The Bilstein 5160/6112 Combo will max out at 2.5 inches of lift. It's the best bang for your buck. If you want 3 inches or higher you need to look at Kings, Fox etc. (Really expensive)
  17. May 12, 2021 at 6:03 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    So I’m not an expert. I researched for about 4 months paying particular attention to my driving style most of the time. Frankly I drive too fast and live to take corners at speed. This puts a lot on spring rates and shock recovery design. I quickly realized a digressive shock suited my primary goal. And while that affects whoops the bump and yawl is the payoff. Then I wanted 285s for looks and clearance but went with 70s to give me no CMC. Lastly I got a killer kit (iCon 8) and set it at 2.125 so it had plenty of room left and wasn’t torquing the lower suspension. Now I can hit speed bumps at 70 and take corners at street lights at 45.
    PinStripes likes this.
  18. May 16, 2021 at 10:50 AM
    4x4.StatlerTaco.XVI
    Los Angeles
    I’m still confused (lol) but I think I’m going with 6112/5100 (on 6/6), shim (for lean), AAL, UCA, and ECG bushings.
    It seems like this is all I would need to get 2.5 in front and 1.5 in rear (I would settle for 2 front 1 rear). At this point I’m settling on bilstein unless eibach comes up as a total package deal when buying.
  19. May 27, 2021 at 10:17 PM
    4x4.StatlerTaco.XVI
    Los Angeles
    Out of curiosity, why go with 5160 in the rear? I see it has a reservoir. Is this for better off road performance? I would be using it 90% of the time as a daily driver. Would I be better off with 6112/5100??
  20. Oct 3, 2021 at 10:58 AM
    4x4.StatlerTaco.XVI
    Los Angeles
    I ended up getting the bilstein 6112 front on 6/5 and 5160 rear with icon 3 leaf add a leaf. I went with the spc UCA’s.
    I installed everything myself. Noticeable different but I still want extra height lol. Looks really good though.
