suspension mersurements
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, May 6, 2009.
  1. May 6, 2009 at 2:46 PM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    hey does anybody know how u can tell how high 3 inches will go on your truck where do u star measuring at to see how high its gonna go from stock to 3 inches and does anybody have a taco with a 3 inch lift next to a stock taco
  2. May 6, 2009 at 5:31 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Measure from either the ground or the center of the hub to the bottom of the fender well.
    As long as you measure to the same spot with the same tires either way will give you a baseline number to compare to after you install your lift.
  3. May 6, 2009 at 8:14 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    x2
  4. May 6, 2009 at 8:15 PM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    jack your truck up 3 inches... problem solved :)
    orrrrrr... dig a ditch 3 inches deep...
    then sit in it and look at your truck.
