Suspension needs replaced, but confused
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaPantsKey, Nov 4, 2020.
  1. Nov 4, 2020 at 4:50 AM
    KaPantsKey
    KaPantsKey [OP] Well-Known Member
    Kyle
    SC
    13 MGM DCSB TRD-OR
    Stock 2013 Tacoma 4x4 DCOR V6 with 105,000 miles.
    It is time to replace my struts/shocks and I figured now would be a good time to level my truck. From my research I have settled on B8 6112's front coilover/strut combo and B8 5100 rear shock.
    Questions:
    • Is this a good combination? If not, are there any recommendations? I don't want to spend much more than these will set me back. If there is a more economical solution that still offers quality then I am open to that too.
    • Which groove position should I set the front strut to achieve a leveled look?
    • Does leveling require UCA's? I want close-to-stock alignment specs with perhaps +2-3 degrees caster for better highway tracking.
    • Any driveline issues with just leveling the truck?
    • Any reason to replace the rear leaf springs? They all seems in good shape. They were replaced under the TSB around 30k.
    I don't tow with any regularity for it to be a concern.
    I am open to any and all suggestions, so please let me know if I should go about this differently. I am complete newb on this and continue to confuse myself the more I read the stickies and misc. other posts.
  2. Nov 4, 2020 at 4:56 AM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Contact headstrong Offroad. They will answer all your questions :thumbsup:
