Suspension Opinion help.. Toytec Alluma 2.0 vs Billstein vs everything else??
Discussion in 'Suspension' started by LiftKit, May 22, 2023.
  1. May 22, 2023 at 5:10 AM
    LiftKit
    LiftKit [OP] Well-Known Member
    Hello TW, it has finally come to the time for me to swap out my suspension, wheels and tires.
    With that being said, I found a shop local to me that specializes specifically for tacoma lifts and upgrades which is really fortunate for me.
    I do mostly road driving with the occasional hunting trail, beach camping.
    Because of this, I really don’t need a huge lift, just wanted a better suspension over stock that’s “softer” and rides easier on and off road.
    after doing much research, I settled on a tire size of 255/80/70.
    Talking with the shops rep, they were highly pushing the Toytec Alluma series 2.0 with a Toytec add a leaf for about 2” of lift. With install and alignment for just the lift portion, total would be like $2,300 without the tires and wheels.
    My question for all the TW suspension gurus is, is this worth it for the results I’m trying to achieve? I get the Toytecs are rebuildable, however that’s not really a selling point for me as I would have to go to a shop to get them rebuilt anyway.
    My total budget for the lift portion is around 2,400$ and I don’t really want to spend more than that. I’ve read that billstein 6112/5160 are an even cheaper but yield the same ride quality which has me rethinking everything. I inquired about fox 2.0s with the shop and the guy told me he didn’t recommend them for what I’m trying to do.
    Just really confused on what I could be spending my 2,400 lift portion budget on now. Any advice would be much appreciate..
    wayupnort likes this.
  2. May 22, 2023 at 5:22 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Check out Dobinsons Suspensions at Exit Off Road. They have lots of options.
    As for for installation, lots of videos on YouTube university. Doing it yourself you'll get lots of self satisfaction.
  3. May 22, 2023 at 5:28 AM
    LiftKit
    I’ll check it out however I have no desire to install the lift myself because I get very little free time as is. Any thoughts to the Toytec 2.0? Was my main concern about the setup
  4. May 22, 2023 at 5:28 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    You’d probably do well with the 6110 front and 5160 in the rear with a block or AAL. Reach out to @memario1214 at HotShot Off Road for a good deal.
    Sorry can’t help with the Toytec lift, or really offer any real feedback about the 6110 besides it’s a popular choice around here.
    Depending where you are, you could find a local TW member to help you instal for possibly beers or something. If you don’t care about having a shop stand behind their work.
  5. May 23, 2023 at 7:09 AM
    LiftKit
    BUMP
  6. May 23, 2023 at 7:15 AM
    wayupnort
    wayupnort Well-Known Member
    Do you really need a lift or just want a better ride/ look?
  7. May 23, 2023 at 7:23 AM
    eurowner
    eurowner Duke Sky
    Scoty
  8. May 23, 2023 at 7:34 AM
    LiftKit
    well I’m wanting to run a 255/80/17 so I don’t think I even need a lift.. just want better suspension. I was thinking 2” was a good compromise because that’s how much most aftermarket coil overs give you. I’m also replacing the bushings with ECGS one because why not.
  9. May 23, 2023 at 7:35 AM
    LiftKit
    Exactly that thread had be scared about the aluma series and I’ve seen other members say that the suspension is too stiff
  10. May 23, 2023 at 7:44 AM
    eurowner
    eurowner Duke Sky
    Scoty
  11. May 23, 2023 at 7:46 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Bilstein allows stock height on their coilovers (5100, 6112, 8112) with superior dampers
  12. May 23, 2023 at 9:21 AM
    LiftKit
    are you saying the billstein setup is better and a better value overall vs the Toytec?
  13. May 23, 2023 at 1:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Without a doubt.
  14. May 25, 2023 at 4:13 AM
    LiftKit
  15. May 26, 2023 at 2:21 AM
    Houstoner
    Houstoner Well-Known Member
    Daniel
    2020 DCSB SR V6 4WD
    I went through toytec because all my tools are back home in Texas, but if I could install it myself I would. That said the toytec brand is just rebranded Elka shocks, in my personal opinion if I were you id go 6112 in the front and 5160 in the back and maybe get some dobinson leafs or deavers if you want to splurge a bit. The company overall is decent a little difficult to get ahold of at times but the knowledge they bring to the table can be very helpful. One thing you will notice in their parking lot is that hardly anybody who works there runs the aluma shocks on their own personal rigs, to me that says something. The sales rep i dealt with at toytec was a bit of a burnout but he was honest with me about toytec shocks which i appreciate. Also lead times for those aluma shocks were about 3 months from my understanding. I ended up going with fox 2.5 DSCs front and rear with deaver stage 2 leafs, is it overkill absolutely. Getting them installed next week there.
    JFriday1 and eurowner like this.
  16. May 26, 2023 at 7:51 AM
    eurowner
    eurowner Duke Sky
    Scoty
