Suspension Options: Fox Performance Elite or Dobinsons MMR 3 Way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrhzn, Jun 21, 2023.
  1. Jun 21, 2023 at 6:53 AM
    jrhzn
    jrhzn [OP] Well-Known Member
    Westminster MD
    2015 TRD PRO
    Icon stage 10 suspension, Falken Wildpeak AT3 33” tires, Leer Cap, AuCar Headunit, Morimotyo headlights and more.
    Hi there, trying to decide between these two options and was hoping Tacoma World Members had exerience with both and could share their experience.
  2. Jun 23, 2023 at 2:45 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    If you live in the salt belt I’d steer clear of Fox they corrode and rust up like the titanic in short order.
  3. Jul 8, 2023 at 7:43 AM
    ktmtacoguy
    ktmtacoguy Active Member
    2021 Tacoma TRD Off Road DCLB
    Ironman 3" Foam Cell suspension lift, Black Rhino 17" Stadium wheels, 285/70/17 Falken Wildpeak AT3W tires, Body Armor Hiline front bumper, Smittybilt X20 winch, Diode Dynamics front low beam/high beams/fogs.
    The Performance Elite's have aluminum housings. No rust.
  4. Jul 8, 2023 at 10:01 AM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    Disclaimer: I haven’t owned the dobinsons mmr shocks but it was an option on my list of choices so I did look into them.
    I have had several brands of coil overs and just upgraded from the OME Bp-51 kit to the fox 2.5 DSC extended travel and 2.5x12 rears.
    the BP51 had compression and rebound adjustment which was very appealing to me as most brands don’t have rebound adjustment. This ultimately caused me to spend more time tuning and tweaking them just because it was an option. Looking back, most of the time I didn’t actually need to adjust rebound.
    The only thing I adjusted semi-regularly was compression when going from an all dirt 4x4 trip back to street driving (daily driving to/from work). I’d turn down the compression for a cushy ride on the freeway and turn up the compression when towing heavy.
    With the fox 2.5 DSC I sent them to @AccuTune Offroad before installing them for the “adventure” type tune and they are dialed in! I adjust the compression knob a bit for daily driving vs high speed off road.
    Also, I have zero signs of corrosion on my fox 2.5s but I’m in southern California so no road salt :D
    Ultimately if you are someone who loves doing a lot of tuning for each different type of driving the dobinsons would be a great option. If you’re like me I just want to get my suspension dialed in once and only make a minor tweak between on/off road driving then get the shocks tuned and let it be.
  5. Jul 10, 2023 at 10:12 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I have the Fox PES. They have problems breaking adjuster knobs. If I were buying again tomorrow I'd look very hard at the Dobinsons.
