Suspension question help
Discussion in 'Suspension' started by silver09tacoma, Apr 14, 2021.
  1. Apr 14, 2021 at 5:25 AM
    silver09tacoma
    silver09tacoma [OP] Well-Known Member
    2009 Tacoma TRD sport
    Hi everyone, new tacoma owner and i'm looking to install a small lift, 2-2.5 in. I am planning for bilstein 5100 with oem coils on second to top notch for front, but the back is where I am confused. I am planning to use AAL pack for rear which says it will give 2 in also. Do I need to replace the rear shocks with ones that give 2 in along with the leaf pack? Or can I still use stock rear shocks with the leaf pack? Thanks
  2. Apr 14, 2021 at 8:07 AM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Depends on your truck and your intended use. You might be able to get away with stock rears, but they were designed for stock ride height and you are adding height, so you will lose that much down travel. Do you need the down travel for your use?
  3. Apr 14, 2021 at 8:11 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I would get new rear shocks as well, as the add a leaf will increase the thickness of the pack, making the extended length (drooped out) of everything longer. This will make the shock potentially act as a limiting piece, and lead to failure.
    Slightly longer (ones good for 1-2” lift”) Bilsteins shouldn’t be much more money at all.
  4. Apr 14, 2021 at 8:11 AM
    silver09tacoma
    I don't necessarily need the down travel, but do I occasionally haul some things and I don't want a harsh ride.
  5. Apr 14, 2021 at 8:14 AM
    silver09tacoma
    Gotcha, thanks. Would you recommend 5100's for rear too or a different shock?
  6. Apr 14, 2021 at 8:19 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Not sure if 2nd gens are like 1st gens as far as the brake proportioning valve bracket but if you are going 2 in up in the rear, you might need to make a bpvb out of a piece of scrap steel unless your AAL setup sends you one.
    silver09tacoma[OP] likes this.
  7. Apr 14, 2021 at 8:21 AM
    Sterling_vH111
    Sterling
    socal
  8. Apr 14, 2021 at 8:22 AM
    Sterling_vH111
    Sterling
    socal
    OP shouldn’t have an issue. I used to have a 2” add a leaf and had no problems with brake line length.
    71tattooguy and Matic[QUOTED] like this.
  9. Apr 14, 2021 at 8:24 AM
    Matic
    Tricky Dick
    Easley, SC
    Not brake line length.
    The brake proportioning valve bracket length.
  10. Apr 14, 2021 at 11:26 AM
    Sterling_vH111
    Sterling
    socal
    Ah, I didn't catch that. Any event I did not have to mess with any of that stuff.
