Suspension question (im new)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Shabutie, Mar 30, 2013.
  1. Mar 30, 2013 at 8:43 AM
    Shabutie
    Shabutie [OP] Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    I've decided I do want to lift my truck just a little. My question is does the bilstein 5100 lift and spacer lift work to lift it 5-6 inches together? I couldnt find any write ups on those two together. I don't want that much of a lift so if they do lift it more than 3 inches which way is better?
  2. Mar 30, 2013 at 8:50 AM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    No, it doesn't work like that. In order to get that much lift you would need a drop bracket lift. 3'' is about the most you can go without a drop bracket.
  3. Mar 30, 2013 at 8:51 AM
    mountainman94
    mountainman94 awwwwww yeeeeeeeeahhhhh
    Cory
    A Place of Higher Learning
    '98 TRD SR5
    5100's/Eibach coils; 2 inch toytech AAL, Black Pacer 15x8 wheels, 32x11.5 BFG AT K/Os
    If you use the Bilstien 5100s, then you don't need a spacer lift. Putting both on would actually damage your truck. the 5100s will give you about 2-3 inches of lift, which is usually perfect for these trucks.
  4. Mar 30, 2013 at 8:52 AM
    Shabutie
    Zach
    Fort Stewart
    Ok good. All I want is 3" max. Which option is better for a comfortable ride?
  5. Mar 30, 2013 at 8:53 AM
    mountainman94
    Cory
    '98 TRD SR5
    Definitely the 5100s. The best option would be to get the Eibach coils with the 5100 shocks and install them together. That's what I have and it both rides great and looks great. If you want to buy just the shocks, that will still be an improvement over a spacer lift.
  6. Mar 30, 2013 at 8:54 AM
    Shabutie
    Zach
    Fort Stewart
    Ok and what about the back?
  7. Mar 30, 2013 at 8:57 AM
    mountainman94
    Cory
    '98 TRD SR5
    Rear AAL
    This is what I put on mine, it's just an extra leaf spring (flat arched piece of metal) that arches the rest of them more and lifts the rear. This will lift the rear about 2 inches, but you'll need to get the rear 5100 shocks to go with it, because the stock rear shocks aren't long enough.
  8. Mar 30, 2013 at 8:59 AM
    Shabutie
    Zach
    Fort Stewart
    10-4 man thank you. This is my first tacoma I came from jeep so I wasn't sure. I usually lift with blocks in the back. Ordering my kit as we speak and my work will install it all for free. Thanks for the advice buddy.
  9. Mar 30, 2013 at 9:01 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    What do you mean by comfortable ride because lifted trucks are normally stiffer then factory. If your looking for a plush ride I wouldn't lift it. Most of us think the stock ride it too soft so in turn we like the way the lifted truck rides. I had 5100's and Eibach springs and i loved it but it was a stiffer ride over the factory setup but It was what I expected.
  10. Mar 30, 2013 at 9:02 AM
    Shabutie
    Zach
    Fort Stewart
    I'm not expecting a Cadillac haha just more comfort out of both options
  11. Mar 30, 2013 at 9:04 AM
    mountainman94
    Cory
    '98 TRD SR5
    This. It's definitely gonna ride like a truck, but since I was replacing suspension that had nearly 300,000 miles on it, I did notice that it seemed more controlled and just better in general.
  12. Mar 30, 2013 at 9:22 AM
    Shabutie
    Zach
    Fort Stewart
    One more question. Is the shocks the same in the front and back?
  13. Mar 30, 2013 at 9:24 AM
    mountainman94
    Cory
    '98 TRD SR5
    No, they're different. If you plan on getting just the shocks for the front and back, you can look here.
  14. Mar 30, 2013 at 9:26 AM
    Shabutie
    Zach
    Fort Stewart
    Yea im looking there but the are way overpriced. I can get them for $80 a shock
  15. Mar 30, 2013 at 9:32 AM
    mountainman94
    Cory
    '98 TRD SR5
    If you're buying them individually, then you can search the part numbers on here.
  16. Mar 30, 2013 at 9:35 AM
    2013 2.7
    2013 2.7 Well-Known Member
    13 PreRunner
    dont get the shocks at autozone there extremely overpriced there i was going to get them from autozone right down the road but it as like 500 just for the shocks
  17. Mar 30, 2013 at 9:42 AM
    Shabutie
    Zach
    Fort Stewart
    ouch. Im gonna see if work has them.
  18. Mar 30, 2013 at 12:49 PM
    03taco88
    03taco88 Well-Known Member
    South MS
    Stock for now Mods to come 6" w/35's HID's 5% tint
    Could he go more than 3" if he had a prerunner?
  19. Mar 30, 2013 at 1:06 PM
    mountainman94
    Cory
    '98 TRD SR5
    He could, but OP isn't a prerunner...
  20. Mar 30, 2013 at 1:14 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
