Suspension Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by smoltz, Jan 9, 2011.
  1. Jan 9, 2011 at 8:15 PM
    smoltz
    smoltz [OP] New Member
    I've got a 2004 DC 4x4. The back has a bit of sag at this point and I think it might be time for some new shocks. I was thinking about getting some Bilstein 5100s and then adding a longer shackle in back to give me about 1" of lift. Is this a sensible plan or is there some better approach (add a leaf, block)?
    Also, I know that you're not supposed to use the 5100s in back without a lift. Is 1" enough to be OK?
    Overall, I'd like to be level about .5" higher than stock (to give a little bit of extra clearance for my 265/75s) and level.
    Thanks,
    Adam
  2. Jan 10, 2011 at 6:00 AM
    smoltz
    16" Factory Rims
  3. Jan 10, 2011 at 6:15 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Sagging comes from the spring. The stock shock has very little preload (just enough nitrogen to be compressed to account for shaft intrusion). Would recommend add-a-leafs.
  4. Jan 10, 2011 at 6:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Sag is caused by the springs, not the shocks. So before you lift using a shackle...I'd get some new springs or get the ones you have re-arched or an AAL.
    THEN look at new shocks based on your mileage...
  5. Jan 10, 2011 at 6:16 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Well you can use the billy 5100s with stock suspension. Now for rear lift i would recommend a add a leaf if you tow alot(the aal gives 1.5-2" of lift), and i would recommend blocks and lift shackles if you are just on the road. Also shackles work pretty good offroad.
    Hope it helps.
