Suspension Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swivot, Nov 9, 2017.
  1. Nov 9, 2017 at 1:10 PM
    Swivot
    Swivot [OP] Well-Known Member
    Im looking for new front shocks and coilovers for my 2001 Tacoma V6 4WD. Whats the difference between paying lots for OEM bilsteins and coilovers and going a cheaper route like this package from Rockauto http://www.rockauto.com/en/moreinfo.php?pk=3443685&cc=1375343&jsn=399
    Will I really notice that big of difference for a begginer offroader? Will the cheaper ones just not last as long? Thanks
    TacoTacoma97 likes this.
  2. Nov 9, 2017 at 1:32 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I recently got new shocks from Rockauto, but instead of that package deal, I got
    KYB 564001 MonoMax & 500# OEM springs. Love em just fine. Don’t need my truck jacked any higher, so I went with these.
  3. Nov 11, 2017 at 8:22 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Over my 55 years of driving I had to replace many, many shock absorbers on my cars and trucks. It's been my experience that at about 40k miles (some earlier, some later) a shock absorber begins to fade to the point where it is noticeable. I've had various types of Gabriel and Monroe on various vehicles, and they all worked nicely for the first 10k-20k miles. For example, I had to replace the original set of front and rear shocks on my TRD at 60k miles, and my rear shocks again at 70k miles. And now at 92k miles I had to replace the front shocks again. I suspect the rears are not far behind.
    Over the last 20 years I've driven a lot of miles on some really bad, knarly, washboard roads (paths?) in the Nevada and Utah forests and deserts, in many places I averaging 2-3 mph for 15 to 20 mile stretches. When you figure the many 1000's of times a shock retracts and rebounds an inch or so each mile, and the millions of times it retracts and extends over a couple of days of washboard dirt roads, it's a wonder they last at all...
  4. Nov 11, 2017 at 8:28 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Spend a little more money and get some quality Bilstein 5100s
  5. Nov 11, 2017 at 1:11 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    The kyb monomax mentioned above ride every bit as good as bilstein 5100s for a bit cheaper. Only difference is height is not adjustable.
    Yes, spending a bit more on quality shocks does improve ride quality, and that is coming from someone who is all about cheaping out on anything possible.
    Kleenax likes this.
  6. Nov 11, 2017 at 3:16 PM
    Kleenax
    Ray
    Michigan
    I've been running KYB shocks for about 40 yrs now, and like them perfectly fine, and they're not cheap, but they are inexpensive compared to Bilstiens.
    vern650[QUOTED] likes this.
