Suspension question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doris_the_taco, Mar 14, 2020.
  1. Mar 15, 2020 at 1:03 PM
    07tacomatoy
    07tacomatoy Shoots den
    Pacific Ocean
    2007 4x4, 2019 TRD SPORT 4x4
    Right on - go for it! I been debating hard a couple months now I just decided to go for it.
    Just so you guys know there are Eibach coilovers coming out for our trucks. I think they’ll be around $599 for the front only. Just FYI
    Jessel[QUOTED] likes this.
  2. Mar 15, 2020 at 1:12 PM
    doris_the_taco
    doris_the_taco [OP] Well-Known Member
    Ian
    2008 Tacoma TRD Off-Road
    Ok thanks for the help. Are you doing anything else to the rear?
  3. Mar 15, 2020 at 3:21 PM
    07tacomatoy
    Pacific Ocean
    Just adding the single AAL - 1.5” I think.
    Also, I’m putting in UCA - JBA high caster ($450).
    I’m replacing my entire front suspension this is why I’m throwing the lift in - I used and abused my stock suspension 175k lol time for new.
  4. Mar 15, 2020 at 9:26 PM
    doris_the_taco
    Ian
    Alight cool, thanks for all the help and good luck with the taco
  5. Mar 22, 2020 at 8:45 AM
    doris_the_taco
    Ian
    Is there anyway to just tighten one of the coils instead of spacers because i’m struggling to find the right spacers. What did you go with?
  6. Mar 22, 2020 at 11:26 AM
    07tacomatoy
    Pacific Ocean
    No you can’t just tighten one coil both coils need to have the same setting.
    Brands - Toytec or headstrong
    I ended up just getting one 1/4” for drivers side lean but I’m probably not going to install it because it’s a top plate spacer and I wanted a in coil spacer.
    **If youre going to use spacers it’s best to get in-coil spacers.
    Don’t go too crazy with the spacer ok to do like a 1/2” but anymore and your taking away from up or down travel.
    There’s a lot to it but make sure you read the lift faq: https://www.tacomaworld.com/threads/suspension-lift-info-includes-pics.142677/
  7. Mar 22, 2020 at 11:28 AM
    doris_the_taco
    Ian
    Alright thanks
  8. Mar 22, 2020 at 11:56 AM
    07tacomatoy
    Pacific Ocean
    You know what never mind what I said It’s ok to get top plate spacers just don’t go too crazy high with them (the lift faq explains why). I am going to throw my 1/4” top plate.
