Suspension Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doris_the_taco, Apr 13, 2020.
  1. Apr 13, 2020 at 10:22 PM
    doris_the_taco
    doris_the_taco [OP] Well-Known Member
    Ian
    2008 Tacoma TRD Off-Road
    So if I did added some bilstein 5100s and set them at 1.5” with a 2.5” coil, would that give 4” lift? If not how does it work?
  2. Apr 13, 2020 at 10:31 PM
    doris_the_taco
    Ian
    i’m just trying to figure out how it works
    tcBob likes this.
  3. Apr 14, 2020 at 4:28 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    It doesn’t work. Lift should come from the coils or the shocks but not both. If you have lift springs the 5100s are supposed to be set at 0.
    whatstcp and lynyrd3 like this.
  4. Apr 14, 2020 at 4:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Shocks don't lift anything. Ever. Springs create lift.
    Only reason 5100's are used for 'lift' is they have choices of spring perch selection. Which compresses the spring, creating preload and resulting in lift. But it's still the spring doing the lifting.
    The purpose of shocks (dampers is a better name) is to control the springs oscillation.
    If you want a 4" suspension lift you'll have to do a drop bracket lift, which requires cutting out your front cross-member and seriously narrows your buyer market if you want to sell the vehicle.
    And if you are actually off-roading, not just building a poseur vehicle, that type lift does not add any ground clearance. In fact, the only thing that adds ground clearance to the lowest point of the vehicle (which are the axle lines) are taller tires.
  5. Apr 14, 2020 at 9:37 AM
    zdski
    zdski Well-Known Member
    Zach
    Phoenix, AZ
    2011 DCLB TRD Sport
    5100s, AAL, TRD Wheels, 285 Ridge Grapps
    Direct quote from Marie at Headstrong Offroad: "...the Bilsteins are adjustable by changing the notch setting up on the shock body. However by doing this with a lift coil, you compound lift. So instead of seeing around 0.85" (on the 2nd gen 5100's) or 0.65” (on the 3rd gen 5100's) of extra lift you may see an 1"+ more lift. Plus there are other issues at play here like potential coil bind issues. Also by adding additional preload you can affect the ride quality as well."
    I also think it's a terrible idea to add preload to a lift coil. Either adjust the perch setting with your stock coils, or set them at 0 and get a proper lift coil. An OME 887 coil will get you ~3". If you want more lift from this setup, you can look into a top plate spacer.
  6. Apr 14, 2020 at 3:15 PM
    mojojojo78
    mojojojo78 Well-Known Member
    2007 Prerunner Access Cab SR5 V6 6 Speed Manual
    None... yet
    Is your truck 4X4 or Prerunner?
  7. Apr 14, 2020 at 5:56 PM
    stealthyhank
    stealthyhank Well-Known Member
    Isaac
    2011 Tacoma Base
    Aftermarket headlights, taillights, grill, toggle switches for air, and bull bar.
    ... and why would they make fun?
  8. Apr 14, 2020 at 6:01 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    That’s bullshit.
  9. Apr 14, 2020 at 6:02 PM
    stealthyhank
    Isaac
    2011 Tacoma Base
    I’m dying right now. I’ve heard the opposite. The higher the truck the shorter they are.....or the shorter they are
    whatstcp[QUOTED] likes this.
