suspension question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PacoDevo, Feb 20, 2025.
  1. Feb 20, 2025 at 7:46 PM
    PacoDevo
    PacoDevo [OP] Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    ASSUMING my '16 SR5 is stock height (haven't measured it yet) if I put on new coil overs and rear shocks that are factory set for a 1.5" lift, will I have any issues?
    Adding after market UCAs also.
    Thanks, Pops
  2. Feb 21, 2025 at 6:18 AM
    PacoDevo
    Pops
    Bazetta Twp. Ohio
    Measured from center of hub to fender lip on both front and rear ends and it appears I am at stock height.
    Do I need to worry about other issues if I add a 1 1/2" suspension lift and new after market UCAs???
    Would like to order soon so any help would be greatly appreciated!!!
    Pops
  3. Feb 21, 2025 at 6:25 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Nope, usually you want new UCAs above 2.5 inch. Depending on what you’re putting in the rear, you might need an add a leaf or spacer.
    You may need to worry about the needle bearing, but everyone does, if yours is 4x4. See this thread about that. https://www.tacomaworld.com/threads/needle-bearing-yes-replace-it-ecgs.716338/
    What kit are you going with? If Bilstien, I’d recommend reaching out to Colton, @memario1214 and Hotshotoffroad. He can help answer questions and is much more knowledgeable than I am.
    memario1214 and 908tacoma like this.
  4. Feb 21, 2025 at 6:39 AM
    eurowner
    eurowner Duke Sky
    Scoty
  5. Feb 21, 2025 at 7:12 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    SHORT answer is that you will not have issues. The rear shocks may be too long and bottom out before the bumpstop makes full compression. However, most 1.5" rear lift shocks on a Tacoma can still work in a stock height fitment application.
    hyrule_trd and 71tattooguy like this.
  6. Feb 21, 2025 at 7:15 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    You should be fine, but after you install the lift, you have to get under your truck and check that the fins of the inner boots of your CV’s are not touching each other.
    Mine were after a 1.5 inch lift so I popped off the OEM clip, and slid the boot over a tiny bit and cinched it down with two hose clamps. (CV boot slide mod)
    skip the UCA’s for now
  7. Feb 21, 2025 at 4:08 PM
    PacoDevo
    Pops
    Bazetta Twp. Ohio
    Well, thanks everyone.
    My UCAs are rusted pretty good and I figure as long as I am going to change the coil overs, I figured I may as well do the UCAs at the same time since I already bought them.
    Went with the Elka 2.0 set up and Ironman Pro UCAs.
    eurowner and hyrule_trd like this.
  8. Feb 22, 2025 at 7:52 AM
    PacoDevo
    Pops
    Bazetta Twp. Ohio
    Anyone have part #s or actual sizes/grades of all needed hardware to re-attach (tops and bottoms) the new coil overs/rear shocks???
    I am assuming the current/original ones will not be worth reusing after 72,000 miles and rust covered.
    No idea if new ones will be included or not with the Elkas?? I do know I need new top bolts for the UCAs and have found them online already.
  9. Feb 22, 2025 at 8:17 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
  10. Feb 22, 2025 at 9:26 AM
    PacoDevo
    Pops
    Bazetta Twp. Ohio
    Thanks for the info!
    hyrule_trd likes this.
  11. Feb 24, 2025 at 10:10 AM
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Good reference for me to fall back on when I start ordering some front end parts this next month.
  12. Feb 24, 2025 at 2:56 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    you might have issues...sometimes the alignment gets out of whack if it ain't done right.
