Suspension questions...
Discussion in '1st Gen. Tacomas (1995-2004)' started by redrckhiker, Apr 28, 2011.
  1. Apr 28, 2011 at 7:29 PM
    redrckhiker
    redrckhiker [OP] Member
    Henderson, NV
    2001 Double Cab 4WD
    So, made up my mind I'm gonna do the OME 880/881's to go with my 5100 Bilsteins; I may want a 1" lift, but not if that means I have to do UCA's. If I go with the 880's with the 1" lift, do I need to do the UCA's? If I stick with the 881's I assume their stock, standard height springs? So in short, I may do like a one inch lift, but the UCA stuff may be more than I can do, not sure. If I can do the coil/shock replacement, if I need to do the UCA's, is this significantly more difficult?
  2. Apr 28, 2011 at 7:31 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Your not gonna need new uca's, ive got a 3" lift and my stock uca's are fine
  3. Apr 28, 2011 at 7:41 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    OME 881's with 5100's set on zero...2" lift and all is good, no need to change the UCAs
