Suspension Recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Docnessponster91, Jul 30, 2019.
  1. Jul 30, 2019 at 12:44 PM
    Docnessponster91
    Docnessponster91 [OP] Active Member
    Nick
    Riverside, CA
    2014 Toyota Tacoma, White, Double Cab, short bed Pro comp 6 inch stage II Kit with MX2.75 Coilover front shocks and Pro runner rear shocks 305/70R18 Mickey Thompson ATZP3 Method NVs ARB front bull bar Fab Fours Rear bumper and tire carrier ARB rear locker and compressor G2 456 front/rear gears Leer Truck Shell
    I have a 2014 DCSB presently with a 6" ProComp Stage II Kit, 456 gears, rear arb locker and all the other armor you could want. The truck is capable off-road, no doubt. However I'm not getting the quality of a ride I want, to include the truck is extremely ''bouncy'' over even the smallest of obstacles which pose other challenges on the trail.
    Any recommendations on how to improve the quality and a make more capable not only as a dd but off-road would be appreciated.
  2. Jul 30, 2019 at 12:48 PM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Is it 2wd or 4wd?
  3. Jul 30, 2019 at 12:48 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I assume you just have the stock length shocks with a spacer for them and that DB lift. I would get a higher quality coilover made for that lift like king or fox and the proper spring rate and have the shocks tuned. Same goes for the rear. A quality tuned shock no matter the brand is better than an out the box shock. Even out of the box a king or fox will be better than a stock length shock like a 5100 with that huge spacer.
  4. Jul 30, 2019 at 12:51 PM
    Docnessponster91
    Nick
    Riverside, CA
    4wd
  5. Jul 30, 2019 at 12:57 PM
    Corny Taco
    Blake
    Yeah I’m gonna agree with this here^
    I assume you want to keep the 6 inches of height. 4wd is what makes it hard because of getting the front up to the right height. Some 4wd guys will have to chime in on this. For the rear you can either get some custom Alcans made for 6 inches or get some dakars and do a shackle flip.
  6. Jul 30, 2019 at 12:58 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    King and fox make coilovers for these lifts
  7. Jul 30, 2019 at 1:01 PM
    Docnessponster91
    Nick
    Riverside, CA
    I just have the MX2.7 coilover front shocks and rear prorunners, with a my stock leaf pack.
  8. Jul 30, 2019 at 1:03 PM
    Docnessponster91
    Nick
    Riverside, CA
    I'm not opposed at giving up the 6 inches of height however I would like to keep my 305s in the process. I had a buddy of mine talking to me about converting to an Icon suspension but I'm not versed in the particular stages in regards to my needs.
  9. Jul 30, 2019 at 1:11 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    So you have a DB lift bad thing about going shorter is you'll have to fix the cut cross member. If you swap what shocks and coilovers you have for the kings or Fox's then you'll see a difference especially with the coilovers with a proper chosen spring rate.
    An icon lift won't work with your current set up. To be honest a lot of guys are running 35s on 3" of lift just requires more trimming of fenders and cab mount than that 6" lift.
