Suspension Ride, Wet Traction & Tire Pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mcman56, Dec 9, 2024.
  1. Dec 9, 2024 at 7:40 AM
    mcman56
    mcman56 [OP] Member
    2016 Tacoma
    I bought my 2016 Tacoma extended cab 2wd V6 new and it now has 83K.
    • The suspension is now feeling stiff but I'm not sure if it is the truck or me getting older. Can shocks get stiffer over time? I would expect the opposite. Can new shocks help? I mostly use it like a car but do haul lightweight dirt bikes.
    • Wet weather traction is really bad, worse than I remember when new. I run the recommended 35 psi. Can you run lower pressures when using it for light duty service? Does it help wet weather traction? The tires do show Traction A but are a Les Schwab brand.
    Tire Pics
    https://ibb.co/89rMZkh
    https://ibb.co/JmwkzVp
  2. Dec 9, 2024 at 8:10 AM
    eurowner
    eurowner Duke Sky
    Scoty
    What type of tires for LS? Post a link to what you have.
    The door jamb air pressure sticker says 30psi IIRC.
    Tocamo likes this.
  3. Dec 9, 2024 at 1:13 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    30, like Scoty said!
    Do you need new tires? Your rear shocks could be done from the bikes, or it could be the rear springs
  4. Dec 13, 2024 at 6:42 AM
    mcman56
    mcman56 [OP] Member
    2016 Tacoma
    These are the tires. They are not worn out or old. I'll go back and check pressure.
    https://www.lesschwab.com/tires/bac...L6rfSiscd53ybzi23UZoOLAGqBJiH9RwaAkDIEALw_wcB
    My concern is wet weather traction of the rear tires when starting from a stop. They lose traction very easily even with moderate acceleration. It has been OV tuned which really woke the engine up so that could be part of it. (The powerband is still kind of lumpy and the transmission can sort of hang under hard acceleration. It will hesitate to shift up. I guess this could be a should be a second posting.)
  5. Dec 13, 2024 at 7:13 AM
    Antboooy
    Antboooy Well-Known Member
    Ant
    Southern Oregon
    2016 Silver Tacoma TRD 2WD
    Bilstein 5100 front and rear Eibach lift springs Freedom Off-road UCAs Torch Off-road 1.5in AAL
    Hey dude, I have a 2wd, also tuned. I can't speak on the shocks. I upgraded to 5100s, they're stiff, which I prefer.
    Like you said the tune woke the engine up. You have to take it easy on the throttle from stop. Otherwise you're spinning wheels. Ask me how I know. I've even taken some turns too quickly and have had the back end slide out, little scary. It's something you definitely need to get used to.
  6. Dec 13, 2024 at 7:19 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Add some weight. It'll soften up the rear end feel and add traction.
    Tires could be getting tired aswell. I do find once a tires is 50% worn or close to the compound is not as effective as when new.
  7. Dec 13, 2024 at 8:02 AM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Dec 14, 2024 at 6:42 AM
    mcman56
    mcman56 [OP] Member
    2016 Tacoma
    This is what I found. Thinking about this. I assume auto shocks lose damping as they wear (although motorcycle forks can get stiffer as the oil becomes "dirty" so maybe not) . If the shocks lose damping, could that actually feel rough due to lack of rebound control?
    Load Index: 111 = 2403 lbs
    Speed Rating: T
    UTQG: 620 A B
    Load Range: SL = A classification of SL means it's a standard load tire
  9. Dec 14, 2024 at 9:06 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    recommended by who?
    Pretty sure the door jamb sticker says 30
    But what does Toyota know? They only built it.
    When shocks wear out they dont have the same damping ability or travel as new so they may feel "stiff".
    At 83 K it deserves and probably needs some maintenance like shocks.
