Suspension sag from bumper
Discussion in 'Suspension' started by Drew5387, Oct 2, 2011.
  1. Oct 2, 2011 at 11:23 AM
    Drew5387
    Drew5387 [OP] You can't fix stupid
    Drew
    Kansas
    03 PreRunner SR5 DC Black
    Raptor Style Grill, KC Highlight Spot Beams, 2.5% Window Tint, Kenwood Touchscreen Head Unit, Train Horn, Tinted Tail Lights, Retrofit Source Projectors with Halos, BHLM, LED Fog Lights, 40" LED Light Bar, 33" Cooper STT Tires, Herculined Rocker Panels, 175+ hp in stickers
    I bought a relentless fab bumper and it should be here sometime this week. I am running a stock suspension right now. How bad is the front end gonna sag from this bumper? What could i do to fix it without getting a new suspension? I can't get a new suspension because of my warranty
  2. Oct 2, 2011 at 11:31 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    if u cant do anything to your suspension then start cuttin material out of your new bumper lol.... not much u can do man....
  3. Oct 2, 2011 at 11:34 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Its not going to sag much. Stock springs are like 600-650lb/in
  4. Oct 2, 2011 at 11:34 AM
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    I'm not sure about the state you live in but you can do a leveling kit, They should not void out any warranty unless they the dealer can prove that the mod effected the original suspension.
  5. Oct 2, 2011 at 11:52 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    So you are saying that replacing the coil springs or putting Bilstein 5100 shocks on the front will void your warranty? My understanding of a warranty affecting the suspension is if suspenion parts are changed that made it unsafe to drive or if the parts were put in wrong which resulted in an accident. I say if the bumper makes your front end sag replace the springs anyway with OME881s or similar. Talk to the seller to make sure whatever spring is used will correct your problem.
