Suspension set at 1.75 instead of 0.85 by accident
Discussion in 'Suspension' started by KingMoo, Oct 27, 2011.
  1. Oct 27, 2011 at 3:15 PM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    I recently got my truck lifted with 5100s all around and Eibachs up front. Today I the alignment done and I was checking out the shocks and it looks like they were set in the wrong position. I thought 0.85 setting was the second notch from the top. They seem to be in the 3rd notch which I think is 1.75
    Should I notice issues and, if not, I may be OK. Or do I have to just take it back and get it all done over again? Sucks to have to pay for a second aligment ($150 done at a different shop) for something they screwed up.
  2. Oct 27, 2011 at 3:16 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Kick them back down a notch before you break something. I'd imagine your CV angles are pretty steep also. You don't want to preload that tall of a coil especially when it's that stiff to begin with. You'll probably like the ride a lot more with the 5100's set at .85 also. It sucks, but you really should reset them.
  3. Oct 27, 2011 at 3:20 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Parker
    Birmingham, AL
    04 taco 4x4 TRD Debadged
    Shrockworks front bumper Shrockworks sliders Tacoma sport rims painted grey 285/70/17 BFG KM2 AEM cold air intake Grey wire mod Donahoe/Icon coilovers 4crawler 1'' BL CBI cutbed rear bumper Bud-Built skids Inchworm e-locker skid
    1.75 isnt very high so you should be fine. Tons of people run them at 1.75. I wouldnt change it unless you have bro-lean.
  4. Oct 27, 2011 at 3:22 PM
    Pugga
    Massachusetts
    Are you serious?? Show me one person running Eibachs on 5100's set at 1.75... Keeping them that high will surely cause the CV's and boots to wear out quicker and it's way too much preload to have on that coil.
  5. Oct 27, 2011 at 3:27 PM
    Rebel Taco 22
    Parker
    Birmingham, AL
    Alright i might have missed the Eibach part :D[​IMG]
    But still, if he doesnt have bro-lean i wouldnt worry about it. Check you cv angle and if its severe then go back down.
  6. Oct 27, 2011 at 3:30 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    I wouldn't know the first thing about whether or not my CV angle is severe or not
  7. Oct 27, 2011 at 3:31 PM
    Pugga
    Massachusetts
    CV issues aside, you'll could potentially bind the coil because you've taken a tall lift coil and compressed it quite a bit. Also, the 5100's will not do a very good job dampening what is now an extremely stiff coil. Do it right, set them back down to .85.
    Snap a pic of your CV's and we'll take a look if you'd like. To give you a point of reference, mine are damn near level between the front diff and the hub. You want them to be at 3 degrees or less ideally I believe. They will operate at a more severe angle, but it will wear them out quicker.
  8. Oct 27, 2011 at 3:33 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Alright, might be a dumb question, probably gonna kick myself later for asking, but if you are 2wd would it be so bad to leave them in that position? I am asking to due a lack of knowledge with this set up, so dont get mad.
  9. Oct 27, 2011 at 3:33 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Take a picture..post it up..
  10. Oct 27, 2011 at 3:33 PM
    Maverick904
    Kameron
    Northeast Florida
    should be fine depending on uca clearance and such.
  11. Oct 27, 2011 at 3:36 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    stock UCAs
    I'll get back with a pic...
  12. Oct 27, 2011 at 3:36 PM
    Pugga
    Massachusetts
    You don't have the CV issues with a 2wd obviously but it's still not a great idea. You could get coil binding or end up doing damage to the strut because they can top out hard. The Eibachs have a high spring rate so preloading them just makes them that much stronger. If you want more lift out of a 2wd, look into spindles, for a 4wd, there's no good way to lift the front end more than 3".
  13. Oct 27, 2011 at 3:37 PM
    Toyota Tech31
    Debary, Florida
    Cool, good to know, thanks
  14. Oct 27, 2011 at 3:40 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I would have it put down to 0.85 right away. When I was looking into this set up a year ago I talked to a rep at Eibach and explained what I wanted to do, and he said either at 0, or 0.85 at the very most. I suspect you are lifted over 3" in the front, which will be hard on the CV's, and it must ride really rough, no? How did the alignment turn out at that height?
  15. Oct 27, 2011 at 3:43 PM
    Pugga
    Massachusetts
    About time back-up arrived, I'm getting out-numbered! :D
  16. Oct 27, 2011 at 3:45 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    The second notch from the bottom is .85 the third notch from the bottom is 1.75. I think it is the right way. I have the same setup
  17. Oct 27, 2011 at 3:54 PM
    Fabulous
    Fabian
    Calgary, AB
    Indeed, are they at the third notch from the top, or third from the bottom? That makes all the difference...
  18. Oct 27, 2011 at 3:55 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    Surprised no one else caught that yet. The bottom notch is 0 and it goes up from there
  19. Oct 27, 2011 at 4:00 PM
    Pugga
    Massachusetts
    :facepalm:
    I hope for the OP's sake it's correct... can't believe I missed that, I just saw 1.75 and said to myself 'oh shit'.
  20. Oct 27, 2011 at 4:46 PM
    Fabulous
    Fabian
    Calgary, AB
    Yeah, me as well.
