Suspension, Spacers and Wheels
Discussion in 'Wheels & Tires' started by Krazie Sj, Aug 29, 2009.
  1. Aug 29, 2009 at 4:29 PM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Since nobody wants to answer my question in the designated thread, I'll start my own.
    In the end I want a LT kit so bare that in mind. But that may be 5 years down the road FYI.
    I'm after new tires and I'm thinking of going 285x75x16. Now if I get 5100s for the front (Canadian truck, came with the TSB) set at 2.5" that should level the truck out instead of having a rake.
    Provided I keep my stock wheels, will I need to A) Trim the fenders and B) Buy wheel spacers? Will spacers help with not having to trim the fenders?
    Am I going to do serious hard core Off roading? Not till I get the LT kit. This will be mostly for highway and cut trails, not mudding or crawling.
    Please keep in mind that I'd like to keep my stock wheels.
    285x75x16+Wheel spacers+5100 set @ 2.5"= No rubbing?
  2. Aug 29, 2009 at 4:34 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    its kind of a hit and miss thing for each person. you will be rubbing on the uca's with 285's on stock wheels so you are going to have to have wheels spacers. and you might have some minor trimming on the fender wells too. but again, its a hit and miss kinda thing.
  3. Aug 29, 2009 at 4:34 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    edited... if you keep stock rims, you'll be fine.
  4. Aug 29, 2009 at 4:35 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    plenty of guy on here running spacers with no problems
  5. Aug 29, 2009 at 4:37 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'm pretty sure you'll rub without wheel spacers on stock wheels.
    EDIT: Meteorman beat me to it. :eek:
  6. Aug 29, 2009 at 4:37 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I thought spacers would help eliminate rubbing, cause you're moving the wheel out of the well and furthering the space between the tire and the UCA.
  7. Aug 29, 2009 at 4:38 PM
    DrRabbitFurHead
    Salem, VA
    Yeah, I edited my comment. Sorry... I was thinking about after market wheels, not stockers.
  8. Aug 29, 2009 at 4:40 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    actually when i put the lift on my truck, given it was 3" not 2.5, i had no rubbing on my stockers with 285/70/17 tires except on the uca. i put a 1/4" temporary spacer until my moto metals came in. i still did not rub anywhere else. once i put my moto metals on (they are 1.5" wider and less backspacing) they rubbed the fender wells like crazy.
    but with 2.5" of lift you are probably going to rub a little bit on the fender wells at full lock or something. again not much, spacers are going to pull the tire away from your uca to stop that rubbing though
  9. Aug 29, 2009 at 4:41 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    So 285's+Stock rims+Allpro/SpiderTrax spacers=very possible.
    Could still have some UCA rubbage, but nothing some lotion couldn't fix.
  10. Aug 29, 2009 at 4:43 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    you shouldnt rub the uca with spacers. just the fender wells. but yes that setup is possible
  11. Aug 29, 2009 at 4:58 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    That I could live with. I just don't really want to Cut the cab mounts or rub the UCAs at full lock.
    I'm guessing the only way to be 100% sure is to get new wheels hey?
  12. Aug 29, 2009 at 5:04 PM
    Incognito
    VA
    That would work the best, IMO. Get something with 4.5 backspacing, 0 to -12 offset, and you should be alright. :thumbsup:
  13. Aug 29, 2009 at 5:09 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    x2! you shouldnt have to cut the body mounts or anything. but know that you are still going to rub the fender wells most likely with aftermarket wheels.
  14. Aug 29, 2009 at 5:19 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I just didn't feel like paying another grand or so for wheels. And there are very few aftermarket wheels that I think look good.
  15. Aug 29, 2009 at 6:51 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I like what I'm hearing. I may just have to go this route.
    Muh hahahaha...
  16. Aug 29, 2009 at 7:03 PM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    please post pics, please do :D
    sounds like you should be good to go! lets see some pics when you do it too
  17. Aug 29, 2009 at 7:12 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    It'll be the first thing I do when I get them. :D
  18. Aug 31, 2009 at 8:17 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Those are 285's? In the second picture it doesn't look like it. Although it could just be me.
