suspension squeaks in 2009 double cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlfranks, Jun 9, 2011.
  1. Jun 9, 2011 at 4:51 PM
    dlfranks
    dlfranks [OP] New Member
    TRD Sport
    Has 17 k miles and has started creaking and squeaking - dealer said there was a tsb that has expired and wait for another. Anybody have insights/suggestions?
  2. Jun 9, 2011 at 4:54 PM
    SPORT
    SPORT Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    10,000 on mine and it's squeaking too. More when warm than when cold. So much that it almost sounds like a rattle in the front end.
    Curious to see responses.
  3. Jun 9, 2011 at 4:56 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Dirty suspensions will do that. It's a truck...most truck suspensions squeak. I couldn't care less.
  4. Jun 9, 2011 at 4:58 PM
    HIYota
    HIYota Well-Known Member
    Angel
    O'Fallon, IL originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Mine does too, but I expect it with all the mud I've ran through. Clean up the suspension and lube up them leafs.
  5. Jun 10, 2011 at 1:22 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Dirty?
    With exactly 9,788 miles, it's a show ready mall crawler (for now), and is in no way due to dirt. Now it may have something to do with installing a 3" spacer/AAL level lift recently, but this squeaking/rattle still seems excessive. I'm hoping to have time this weekend to look into it.
  6. Jun 10, 2011 at 2:13 AM
    Murd3rd
    Murd3rd DO WORK!!!
    Garrett
    Abilene, TX
    07 Access Cab 5-Lug...Murdered-R.I.P. 30JUN11
    DJM Lowering Kit, Xrunner front struts and springs, QA1 12-way Adjustable Rear shocks, BHLM, Undercover Bedcover, K&N IK, Doug Thorley Header, URD MAF Cal, ScanGauge, GO-Baby-Go Mod(purple wire mod) Cherry Bomb glass pack dumped right after rear axle, 99-04 Mustang GT wheels Painted Black, Pre-runner Leafs, Hellwig Rear Sway-bar
    pull apart your leaf packs and clean them, then lube each individual leaf with lithium grease.....no more squeaking
  7. Jun 10, 2011 at 2:40 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    And what about the front?
    Lube them as well I suppose...Damn, I just got her re-aligned too.
    Guess she's gonna squeak for a while. ;)
  8. Jun 10, 2011 at 9:25 AM
    Murd3rd
    Murd3rd DO WORK!!!
    Garrett
    Abilene, TX
    are you sure that your front is squeaking? yes you could put some grease on the top and bottom of the coil springs, where ever the spring contacts the strut and the strut hat, but unless you've heard it directly from your front end, i bet its just the rear suspension that is squeaking
  9. Jun 10, 2011 at 9:28 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Maybe it needs more dirt :D
  10. Jun 10, 2011 at 11:02 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    You may be on to something. Maybe it a cry for the wild. :D
  11. Jun 10, 2011 at 11:04 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Oh ya, it's the front suspension. It just started doing it prior to the 3" lift, but is more pronounced now. Ironically, she squeeks more when things are warmed, than when it's cool. Also, when I step on brakes from 10MPH to a stop (just to compress the front end) you hear the suspension squeak quite clearly.
  12. Jun 10, 2011 at 11:27 AM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Put your windows up and turn up the volume! No more squeaking! lol it's a truck, it's going to squeak!
  13. Jun 10, 2011 at 11:27 AM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    mine does it too and i have a 2011, its just the leafs though, im not worried about it
  14. Jun 10, 2011 at 11:44 AM
    Murd3rd
    Murd3rd DO WORK!!!
    Garrett
    Abilene, TX
    then grease them springs
