Suspension, suspension, suspension..............
Discussion in 'Suspension' started by tacobaker, Aug 21, 2020.
  1. Aug 21, 2020 at 4:51 AM
    tacobaker
    tacobaker [OP] Well-Known Member
    Cary
    2017 Inferno TRD
    I've read suspension articles until I am cross-eyed. Time to help an old guy out. I have a 2017 TRD off road. I have decided that my goal is threefold. Improve overall handling, limited lift ( 2 inches) and not break the bank. I would like to keep the budget around 1k.
  2. Aug 21, 2020 at 5:13 AM
    Iyabyas
    Iyabyas Active Member
    Paul
    DCSB TRD OR 4x4
    None
    Bilstein 5100’s are very popular and better than spacer lifts. Tons of info on them on this site. 4 shocks ( 400$) set at 1.75 will raise ur front for a level look. If you want some lift in the back do a AAL ( will raise the rear 1.5” or so). You can also get some ome springs and set the billies at “0” setting and achieve lift. Again, tons of info on here and guys more knowledgeable than me.
  3. Aug 21, 2020 at 5:23 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    AALs are a a budget-friendly option, but they do not last long if you plan on using your truck as a truck. The stock Toyota leaf packs are and will be the lowest common denominator.
    A new leaf pack, with the intentions of using your truck as such, will be the best solution.
    OME is a good, budget kit that will include almost everything you need.
    BalutTaco likes this.
  4. Aug 21, 2020 at 5:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Make your life easy.
    Call Marie @HeadStrong Off-Road and tell her your goals. Install what she ships you.
  5. Aug 22, 2020 at 4:40 AM
    tacobaker
    Cary
    2017 Inferno TRD
    Leaning towards the heavy duty. Takes the guess work out.
    COMPLETE OLD MAN EMU KIT W/ DAKAR LEAF PACK - 2016+ TAC
  6. Aug 27, 2020 at 11:25 AM
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
  7. Aug 27, 2020 at 4:14 PM
    tacobaker
    Cary
    2017 Inferno TRD
    That with a add a leaf may just fit my needs.
  8. Aug 28, 2020 at 7:16 PM
    uncle ed
    uncle ed Well-Known Member
    Ed
    CA Eastern Sierra
    2007 & 2019
    Eibach pro + AAL
    Headstrong talk to Marie
    Checks all the boxes you listed
    taco kai likes this.
  9. Aug 29, 2020 at 7:01 PM
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    Bilstein 6112/5160 and a progressive AAL (three leaf) probably more like 1,300 dollars, but the 6112 is super beefy! 2.65" body is impressive, and you pay for what you get! For a couple of hundred bucks more you will be impressed.
  10. Aug 30, 2020 at 6:18 AM
    tacobaker
    Cary
    2017 Inferno TRD
    We have a winner. centurion, Bilstein 6112/5160 and a progressive AAL. Now for pricing and availability search.. Is there anything else that I should add? Drop kit, etc. And does any AAL (three leaf) stand out above the others? And thank you to all who have responded.
  11. Aug 30, 2020 at 6:20 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I recommend Bilstein 5100's (or better) and 887 OME springs up front.
  12. Aug 30, 2020 at 6:25 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    That leaf pack will still be prone to sagging over time because you're adding it to the stock Tacoma pack.
    Not the end of the world. Just putting it out there.
