Suspension systems and engine suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACTICA1xBEAR, Dec 13, 2016.
  1. Dec 13, 2016 at 11:24 AM
    TACTICA1xBEAR
    TACTICA1xBEAR [OP] New Member
    Bear
    2005 silver Tacoma TRD
    bull bars lift kit wheel set
    I need recommendations for suspension systems and engine if at all possible i hope to get a racing bio-diesel and about another 4" inch lift and recommendations for size of rims and tires
  2. Dec 13, 2016 at 11:40 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    welcome aboard
  3. Dec 13, 2016 at 1:25 PM
    TACTICA1xBEAR
    Bear
    I have the prerunner so its 2wd
  4. Dec 13, 2016 at 1:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What are your goals? Specifc racing class, dune fun, something else?
