Suspension, the overly beaten bush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueWaffleTaco, Sep 29, 2015.
  1. Sep 29, 2015 at 7:27 PM
    BlueWaffleTaco
    BlueWaffleTaco [OP] Well-Known Member
    Brendan
    Stl (wentzville) MO
    2007 Blue Double Cab sr5 trd sport
    SOS CONCEPT ROCK SLIDERS, CALI RAISED LED w/ STEALTH MOUNTS, THULE ROOF RACK, 3" ROUGH COUNTRY BODY LIFT w/ 5100 BILLYS, VISION WHEELS W/ 285 70 R17s, AFTERMARKET HEAD UNIT, SOON TO BE OWNER OF NEW FRAME
    would those ucas work that i posted on here?
  2. Sep 29, 2015 at 7:31 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
  3. Sep 29, 2015 at 7:32 PM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    so about 1300 for it to be done right. anything special in the back besides shocks and aal
  4. Sep 29, 2015 at 7:39 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Include in your budget installing the ECGS front differential bushing.
    FWIW...I have 5100s and Eibach/Toytec 521600 coils and Toytec Progressive AALs and 5160s in rear and my truck rides awesome. You may want to expand your search beyond OME. But then again, I spent a year on here reading, asking PMs to members and decided I wanted something a little different.
    Good Luck!
    Spend more money and do it right the first time also!!
  5. Sep 29, 2015 at 7:43 PM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    see i don't even know what ome means lol I've been assuming stock but that can't be right lol
  6. Sep 29, 2015 at 7:44 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    OEM is stock
    OME is old man emu
  7. Sep 29, 2015 at 7:44 PM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    oooooooo two many acronyms that are similar lol
  8. Sep 29, 2015 at 8:04 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I believe 884s and 885s have the same spring rate, but 885s are taller. 886 and 887 have a higher spring rate and should only be used with heavy bumpers. I wouldn't suggest top plate spacers, they will add lift but sacrifice ride as they add preload to the spring, making it stiffer.
    Going 3" is pretty high on the tacos. You will need UCAs, which add at least $400, will ride rougher, and cause accelerated wear on CVs, which can be reduced with a diff drop but then you are reducing your effective lift height.
    Take a look at the Baja lift thread link in my signature. Not that you would go that route, but just stuff to consider.
    What size tires do you plan on running?
  9. Sep 29, 2015 at 8:09 PM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    So what would be an ideal setup for 2" cause thats really what i wanted as i think my truck already sags below stock as it has 180k on the original suspension. I want to redo it though, could i get 2" out of 5100s with ome 885s no spacers and not need UCAs?
  10. Sep 29, 2015 at 8:12 PM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    https://bilsteinlifts.com/shop/toyo...ilstein-adjustable-lift-kit-with-5100-shocks/ what about this as a complete set and just run it set around 2"? and as for tires, i have no fucking clue lol.
  11. Sep 29, 2015 at 8:23 PM
    smithr1730
    smithr1730 Well-Known Member
    Rob
    Columbus, Ohio
    '15 TX Pro
    Offroad parts and such
    Ok here it is:
    I just put in a lift pretty close to what you want. I ended up with roughly 2.5 inches overall. I am running 5100s front and rear, OME 884 springs, and the wheelers 3 leaf aal. Set the front 5100s to 0 and you should be good to go. You may or may not need UCAs. After the lift is in make sure you get an alignment. This will set everything back to normal and will also let you kno if you need UCAs. I bought everything from Wheelers Offroad. Good luck man!
  12. Sep 29, 2015 at 8:25 PM
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    thats what i had set up originally except 883s, i realize those are wrong now but I'm going for it. if i need ucas santas right around the bend lol
  13. Sep 29, 2015 at 8:26 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    2" is a good height, good ride quality and no need for UCAs.
    i believe the 884s are closer to 2" and the 885s are closer to 2.5" with no additional weight. People that have run them can chime in with first hand experience. It also depends on cab, single, access or double.
    If you stay near 2" you don't need the diff drop. Also do not get the standard Toytec AAL, go with the 3 leaf progressive AAL for better ride. Removing the overload gives 1.5" rear lift and better ride, leaving it in will give 2" and stiffer ride.
    As for tire size at 2" lift, 265/75R16 or 265/70R17 pair vary well (1" over stock). You can see pics in the Baja thread link of what 2" front lift, 1.5" rear on that size looks like. Ideally try to get C-load tires to have minimal impact on mpgs and power.
    ROAD DAWG likes this.
  14. Sep 29, 2015 at 8:38 PM
    OZ-T
    Peter North
    British Columbia
    884 885 and 887 are the same spring rate just different lengths
    886's are a higher spring rate
    Diff drops are ineffective on 2nd gens and 1/4" top plate spacers won't effect the ride
    RogueTRD likes this.
  15. Sep 29, 2015 at 8:40 PM
    #35
    OZ-T
    Peter North
    British Columbia
    You said you wanted 3"
  16. Sep 29, 2015 at 8:54 PM
    #36
    redtacoma63
    redtacoma63 Member
    darren
    2002 tacoma 3.4 manual 3 inch lift
    Don't forget brake lines. I just did the 2" lift and my brake lines were too short to be safe. And, stainless lines are a great upgrade. And a drop bracket for the exhaust, and poly bushings for the leafs and an air chisel to get the bushings out :) and longer Ubolts for the AAL.
  17. Sep 29, 2015 at 8:57 PM
    #37
    OZ-T
    Peter North
    British Columbia
    Do you have a 1st gen ?
  18. Sep 29, 2015 at 8:57 PM
    #38
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks for the correction.
    Drop bracket for the exhaust? You don't need longer U-bolts for the AAL if you remove the overload spring. If you keep it you will. The Icon 3 leaf progressive leaf came with them.
  19. Sep 29, 2015 at 9:09 PM
    #39
    BlueWaffleTaco
    Brendan
    Stl (wentzville) MO
    Originally i wanted 2" but everyone kept telling me that was stupid lol.
  20. Sep 29, 2015 at 9:09 PM
    #40
    millertime89
    Erik
    Saskatchewan
    Yes sir
    2nd gen brah
