Suspension - Tires and Wheels questions...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2010Tacoma4x4, Jan 27, 2011.
  1. Jan 27, 2011 at 9:32 PM
    2010Tacoma4x4
    2010Tacoma4x4 [OP] "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    I know what I want to do with my 2010 4x4 access cab but wanted to run this by the ones who have been there and done that to get your input please.
    First off I am running the stock suspension (no TRD) with factory wheels and tires 245/75/R16.
    1- I already have an appointment for the rear leaf spring TSB next week.
    2-Shocks... Plan to upgrade to Bilstein 5100's front and rear, setting the front at +1.75 is the plan.
    3- Wheels... Looking at a set of 16x8 w/ 4.5in backspace Chrome Helos
    4- Tires.... BFG A/T 265/75/R16
    Could anyone tell me if I will run into any clearance/tire rub issues?? Is there anything I should do different??
    Any advice/input is much appreciated,
    TIA,
    Dave
  2. Jan 27, 2011 at 9:36 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    looks like you did your homework, sounds like a good setup to me. you wont have any clearence issues with that wheel/tire combo.
  3. Jan 27, 2011 at 9:48 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Everything looks pretty good. Except those rims will be pushing it for that width of tire, but as long as you don't air down much then you will be fine, thats is if you offroad and or air down when you go.
    Happy moding days.
  4. Jan 27, 2011 at 9:55 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    i have the same size wheels/tires and never had any probs when airing down to 15psi for sand
  5. Jan 27, 2011 at 10:49 PM
    S.B.
    Sean
    I should of specified. I ment for harder surfaces like rocks. I usually do more slow speed stuff like rock crawling. Thats what I was referring to. In sand you will have no problem, because of the lack of resistance compared to the other.
  6. Jan 27, 2011 at 11:00 PM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Sounds good...I shouldn't need to air down. The only off road driving will be on the beach. Prolly don't even need 4wd but will at least lock it in there once in a while to spin the gears. May need the extra meat at the steep/slick nasty boat ramp now and then.
    Isaac, Your setup looks good....just what I'm looking for. I hope to have this all done in the next couple of weeks. Pics coming soon!!
  7. Jan 27, 2011 at 11:05 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    ^ thanks bro! keep us posted :thumbsup:
