Suspension Travel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRancher, Oct 3, 2022.
  1. Oct 3, 2022 at 12:55 PM
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Will watch it
    trajiiic[QUOTED] likes this.
  2. Oct 3, 2022 at 1:10 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The best that can be done is a quarter-half inch. Not inches for sure. The most simplest concept is to simply draw a triangle on a piece of paper. Now, make one side of the triangle longer without moving the other two line angles.
    Can't be done unless geometry changes and that involves cutting and moving.
    Speedfreak likes this.
  3. Oct 3, 2022 at 1:19 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    8.5” front
    11” rear…. For all Gen 3 Tacomas.
    Amazing you actually asked the one correct question, unlike most of these nitwit just “lift it” , “ how much Lift”, “ what’s your flex“ , “ Distance to fender /lift” , clowns ask daily.
    Most ppls minds will melt with that comment .
    Also this causes great discomfort and confusion for the same clowns: Lift (or ride height) has nothing to do with tire clearance ;)
    No2psi, tstack22 and Speedfreak like this.
  4. Oct 3, 2022 at 1:23 PM
    TacoRancher
    Houston
    All of this education is appreciated. Motor trends says the 2022 PRO has one more inch of rebound travel:
    https://www.motortrend.com/reviews/toyota-tacoma-trd-pro-four-wheeler-of-the-year-2022/
    But based on this technical discussion I cannot figure out if the overall travel increased by an inch by changing the geometry of the suspension or if you lose 1” of travel the other way?
    quote:
    “The high-speed off-road-oriented truck receives new forged aluminum (and red anodized) front upper control arms, new front springs that increase ride height (now 1.5 inches taller than its counterparts), retuned Fox internal bypass shocks with about an inch of additional rebound travel”
  5. Oct 3, 2022 at 1:41 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    You nailed it right there. Answered your own question
    MR E30 likes this.
  6. Oct 3, 2022 at 1:43 PM
    TacoRancher
    Houston
    I see what you mean. I’d like to see it documented somewhere to confirm and I’ll keep looking. But what it sounds like is they shifted the truck’s suspension capability more to high speed than rock crawl.
  7. Oct 3, 2022 at 1:46 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    WHOA WHOA WHOA
    The numbers posted are NOT accurate.
    The IFS front geometry only allows for a 5" shock stroke, while the rear only allows up to an 8" stroke
    MR E30 likes this.
  8. Oct 3, 2022 at 1:49 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    It always has been high speed... that is why they advertise the Pro for desert use.... the snorkel isn't for water crossings...
  9. Oct 3, 2022 at 1:53 PM
    TacoRancher
    Houston
    Yes, that’s what I’m saying — I mean from stock OR, the changes made are more high speed oriented
    Also, I read the snorkel allows you to go totally under water
    tstack22 and skeletron like this.
  10. Oct 3, 2022 at 8:05 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    There is extra travel for the pro. Look up extended travel. Bilstein 5100 have more travel than standard offroad shocks.
  11. Oct 4, 2022 at 3:44 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    The Pro doesn't use Bilstein shocks
  12. Oct 4, 2022 at 7:07 AM
    FloridaFree
    TRD OffRoad 4x4 mgm
    I didn't say the pro had bilstein shocks. look up the pro shocks.
  13. Oct 4, 2022 at 7:12 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    TRD PRO “snorkel” is called desert air intake, it’s not for water crossings.
  14. Oct 4, 2022 at 7:15 AM
    TacoRancher
    Houston
    I know. It was a joke, like when people say that stickers add horsepower etc lol
  15. Oct 4, 2022 at 7:20 AM
    #35
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Right, but the shocks are not attached to the ends of the axles. Wheel travel is therefore more than shock stroke.
    CaptainBart45 likes this.
  16. Oct 4, 2022 at 7:24 AM
    #36
    JoeCOVA
    Joe
    Colorado Springs
    Thats not what OP asked though but the wheel travel variance is only applicable to the front at a 1:2
    MR E30 likes this.
  17. Oct 4, 2022 at 7:32 AM
    #37
    TacoRancher
    Houston
    All I want to know and confirm is total travel in inches of the front and rear suspension, on an OR and a PRO. If they’re the same they’re the same, but just want to confirm. Cannot find any literature or specs on it. I will assume it’s the same based on the posts here and the explained physics / engineering but still would love to see it in black and white.
  18. Oct 4, 2022 at 8:09 AM
    #38
    trajiiic
    trajiiic Well-Known Member
    I don't want to believe the marketing is wrong, I just don't know the measurements of the '22 Pro front shocks. If they're like the Bilstien 5100s with a slightly longer shock body then you may have gotten a tiny bit of extra travel (from my understanding). My thinking is that the marketing people and journalists are just saying it's X amount lifted, therefore x amount extra travel.
    But I would like to see a definitive answer.
  19. Oct 4, 2022 at 8:11 AM
    #39
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    No need to look them up they're on my truck
  20. Oct 4, 2022 at 8:23 AM
    #40
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Where Ya located? We'll take em out there and test em out.
