Suspension TSB + 3" Lift
Discussion in 'Suspension' started by Justin626, Oct 29, 2007.
  1. Oct 29, 2007 at 3:49 PM
    Justin626
    Justin626 [OP] Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    I was wondering if anyone has done a 3" lift after getting the suspension TSB done? SO MANY possibilities out there, I don't know what the hell I'm doing.:frusty:
  2. Oct 29, 2007 at 6:25 PM
    rick
    rick `
    lol i know the feeling justin. heres what you do IMO. have the tsb done. it will give you an additional 1" (approx) of rear lift. the front should remain the same. then have a 3" coil spacer installed on front. and a 1" rear block. thats 2" in the back and 3" in the front. or just go with the bilstein 5100s on top notch. post tsb will be 1" rear lift and 2.5" front lift
  3. Oct 29, 2007 at 7:06 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i've had the tsb done and hopefully w/ schedules, i'll get the 2.5" spacer in the front done in a few weeks
  4. Oct 30, 2007 at 7:29 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    I've wondered how a 3 in lift would work after the TSB. The 3in Toytec lift comes with an AAL for the back. Now if you have done the TSB, do you still need to add a leaf or would that throw off your angles toomuch? do you just ignore the AAL that comes with the lift and put everything else on?
  5. Oct 30, 2007 at 11:51 AM
    Justin626
    Palmer, Alaska
    Yeah, I figured that is what it would come down to. The only thing is I've heard bad things about using blocks in the back. Supposedly it would cause axle wrap (not to clear on the that term), but I don't see why blocks would cause it and not AAL's.
    I know that Toytec suggests going with the rear block if you have the four leaf set up in the back, and they have it as an option in there kits. If you added the AAL, making it 5 leaves total, it would probably make the rear end way to stiff. If you didn't put the block or the AAL, it would probably sit lower in the back.
  6. Jul 10, 2011 at 5:34 PM
    hockeypoor
    hockeypoor Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    Any pictures of a 3in front lift with rear stock(with TSB)?
  7. Jul 10, 2011 at 5:36 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Wow, 4 year thread bump!
    3" in front with tsb rear will leave you nose-high.
  8. Jul 11, 2011 at 1:22 PM
    hockeypoor
    Yes sir even 4 year old threads can still have good info.
    Just for the record I know how it will sit I was asking for pictures.
  9. Jul 11, 2011 at 1:33 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i have the wheelers rear tsb AAL, an all pro u bolt flip kit, and walker evans in the rear for a 3" lift. I run icon Co's in the front. Wheelers TSB AAL is what you need tho
  10. Jul 11, 2011 at 1:41 PM
    TexasTacoma37
    He wants the rear sag look I believe.
