Suspension TSB... what does it mean to me?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjtoc2, Nov 27, 2008.
  1. Nov 27, 2008 at 6:23 PM
    rjtoc2
    rjtoc2 [OP] Burglar of Turds
    Dallas/Fort Worth
    2008 Double Cab Prerunner SR5 (Super White)
    I just bought an 08 Doublecab Tacoma Prerunner/SR5 last week. Do all Tacomas have this problem or is it hit or miss? Since I've been out of a truck for awhile, how will I know if my Tacoma needs the work?
  2. Nov 27, 2008 at 6:34 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Hi. If you have a 3 leaf spring pack you are elligible for the TSB. They will change out the 3 leaf setup to a 4 leaf setup and install 4 new bilstein shocks. If you haul or are planning to haul anything heavy, or you do any towing I would have it done. There is couple of threads on here dealing with how to go about having it approved. I just had it done and the truck feels great, not much different from stock, just a little firmer. Hope this helps you.
  3. Nov 27, 2008 at 6:37 PM
    rjtoc2
    Dallas/Fort Worth
    About the only thing heavy that I'll haul is my new Snuglid tonneau cover when it arrives. I do not even have a tow hitch. Would the 4 leaf setup and bilstein shocks be overkill?
    I have the 3 leaf setup. The letters "CHI" are stenciled on the spring in white letters. I do NOT have the TRD package.
  4. Nov 28, 2008 at 12:17 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Overkill, no. Do you need it, probably not, should you get it, probably. I don't have the TRD either, so they will give you the 4 leafs and replace all 4 of your shocks with Bilstein shocks giving you the same setup as TRD except I heard the coils are different, but I don't know for sure (I'm sure someone can elaborate). Definately better shocks all the way around, which is the main reason I am getting it. I haul a quad a few times a year, mine isn't too bad yet but has bottomed out on rough roads with a load.
  5. Nov 28, 2008 at 9:06 AM
    rjtoc2
    Dallas/Fort Worth
    Will the weight of my Snuglid tonneau cover "balance" the TSB suspension upgrade?
    The truck rides nice now as is from the factory but I am concerned that the constant weight of the tonneau cover/lid will have a bad influence on the ride if I do NOT get the TSB suspension work done.
    Should I have the work done BEFORE the lid is installed? If I brought it to Toyota with the lid installed in the 3-leaf configuration, could Toyota use this as ammunition against me and say that I've made and aftermarket upgrade/change/whatever?
    I realize that the lid is fairly light as it is made fiberglas.
  6. Nov 28, 2008 at 9:20 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Toyota can't use your lid as ammo, dealers add shells & lids all the time so that isn't an issue. The ride will be more "truck like" and they'll tell you that. Mine wasn't a TRD either, just a plain SR5 4WD, but it did bottom out when I towed or had a cabin full of passengers so I opted to do it. The leafs settle after awhile. If you were getting a full shell, it probably would help with rear sag, but you said the lid is fairly light.
    I'm glad I did it fwiw, only you can decide though for the ride will change.
  7. Nov 28, 2008 at 9:32 AM
    Clipper
    Clipper Western Alliance: Sierra's
    Sacramento
    '06 Taco 4X4
    Its FREE why wouldn't you get it done? Anytime someone let alone a stealership gives you something free of charge (My invoice said $1500 worth of repairs) Do it, you will be happy you did. I know i am.
  8. Nov 28, 2008 at 10:11 AM
    rjtoc2
    Dallas/Fort Worth
    With the suspension upgrade, will the rear-end feel "light" and bounce alot?
    That was a problem I had with my 03 Double Cab Prerunner. I'd hit a bump and the back end would bounce so bad that it felt as if the whole rear end was off the ground. This was WITH a tonneau cover/lid and problem 50 - 60 lbs of stuff in the bed at all times. The 03 was NOT a TRD.
    I like the "cush" ride my 08 has now with the 3-leaf arrangement but am concerned that the tonneau cover/lid and stuff in the rear will make the rear end lower and impact the ride and handling.
    I've also noticed that my 08's brakes seem somewhat "soft". Is that related to the suspension TSB as well?
  9. Apr 9, 2009 at 1:29 PM
    skeej
    skeej New Member
    Anyone know if the dealer will honor the TSB on a second owner truck. Thinking of buying an 08 SR5 4wd, and would like stiffer shocks, springs.
    The only thing I think I really need is the LSD/ockers, which I can buy aftermarket, when I later upgrade the rest of the suspension, bumpers, winch etc.
    Suggestions on that would be appreciated- many good builds here, thanks for the info.
  10. Apr 9, 2009 at 2:13 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The factory warrantees should be transferred from owner to owner when it's under the original 3/36. They should honer it.
    If you are past the original 3/36 warrantee - they'll order up the parts and do the work for you but you'll have to pay for all of it.
  11. Apr 9, 2009 at 2:14 PM
    Janster
    Jandy
    Lancaster, PA
    X2
    They should've put these leaf springs on the trucks to begin with. Truck handles much better with the TSB Springs.
  12. Apr 9, 2009 at 3:16 PM
    dragon129
    dragon129 Mod wannabee
    Lexington Park, MD
    05 speedway blue PreRunner Double cab
    No mods
    Yeah no kidding. That's $1500 please.....That sucks, I have 44,000 miles on mine. I would do it myself but Toyota wants $485 for each spring. Sheeeesh... No TSB for me. No spending $1500 either. I guess I'll live without.
  13. Apr 9, 2009 at 3:53 PM
    jacktautog
    jacktautog Member
    imo it was worth all the agrivation,my truck rides so much better even with nothing in the bedthe difference is night and day .JT
  14. Apr 9, 2009 at 5:14 PM
    vtdog
    vtdog Well-Known Member
    NH
    Was the problem corrected for the '09 models?
  15. Apr 9, 2009 at 5:29 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    From the threads I have read they are still shipping all the US trucks with the old 3 leaf packs, most likely they are hoping that the guy that bought a truck really wanted a soft car ride but bought a Truck that he will never haul anything in and notice that the springs are crap
  16. Apr 9, 2009 at 9:05 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Go with an AAL instead. MUCH cheaper and similar result.
  17. Apr 10, 2009 at 12:03 AM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Wish I was under warranty still :(
