Suspension Upgrade 3" to 6" Question
Discussion in 'Suspension' started by jrmitt808, Mar 27, 2012.
  1. Mar 27, 2012 at 10:51 AM
    jrmitt808
    jrmitt808 [OP] Well-Known Member
    JR
    Queens, NY
    2009 Toyota Tacoma DC Sport
    6" BDS Coil-Over System with Fox 2.5 coil-over Shocks , Wheelers 1/4" Top Plate Spacer, AAL, Total Chaos UCAs, TRD Single Outlet Exhaust, Tint,K&N 63 Series AirCharger High-Flow Intake Kit, All Pro Bumper and rock sliders.
    I am in the process of upgrading my suspension, need more height :). I am currently running a 3 inch OME lift kit and want to upgrade to a 6 inch Procomp Stage 1 lift.
    My question is will I be able to use my TC UCAs and OME Shocks on my new lift? Or will I have to replace everything?
    Also I am upgrading my wheels and tires to 18X9 Monsters, any tires you can recommend? I want to stay below 35's. I think 33's Nitto Grapplers would look nice.
    Thanks!
  2. Mar 27, 2012 at 12:33 PM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    The Terra Grapplers might look small IMO. The Mud Grapplers may look better. Matter of opinion though. You should be able to use your OME set up. I think the stage 1 kit is just a drop bracket and blocks..I think. You may need longer shocks in the back but not sure. Don't really know enough about the stage 1 kit. I'm sure someone will chime in..
  3. Mar 27, 2012 at 12:36 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Just an FYI - IMO going from a 3" lift to a 6" DB lift is a downgrade no an upgrade.
    Taller isn't better when you have less ground clearance and are more top heavy.
  4. Mar 27, 2012 at 12:36 PM
    XXXX
    sKiP
    05 Prius
    great minds think alike :)
  5. Mar 27, 2012 at 4:05 PM
    Large
    Large Red
    I don't think you need aftermarket UCAs with a db lift either.
  6. Mar 27, 2012 at 4:07 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    x3
  7. Mar 27, 2012 at 5:08 PM
    jrmitt808
    JR
    Queens, NY
    Interesting...did not know upgrading....uh..hmm...I mean downgrading to a 6 inch lift was a bad thing.
    Anyone out there with a 6 inch lift care to rebuttal?
  8. Mar 27, 2012 at 5:29 PM
    jrmitt808
    JR
    Queens, NY
    Thanks bzzr2 and Jay! I'll be sure to pm you with any questions.
  9. Mar 27, 2012 at 5:31 PM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    true that. good luck with your UPGRADE op!!!
  10. Mar 27, 2012 at 5:31 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    dont use ome coils with it, because then you will be at 9 inches, seems like you have a solid lift now.
  11. Mar 27, 2012 at 6:14 PM
    fj6high
    fj6high Well-Known Member
    Howard
    Tarpon Springs
    07' Fjcruiser
    6"Fabtech +OME Heavies and Custo Skyjackers. Way to much to list.
    I run everything you describe...OME heavy Skyjacker in the back longer then what the kit provides and the stock UCA's.140S struts.
    Don't let the naysayers put you down...I wheel everywhere and I have no issue. I owned both the 2dr and quad Tacomas lifted and not.
    Decide what type of wheeling you intend to do...A bigger lift allows bigger tires and that makes a major difference in performance besides the fact that your approach,breakover and drop off decent angles will be greatly improved. If you have a quad a 6" lift will be a great improvement. I used to get high centered on everything and took damage.
    You decide what type of wheeling you intend to do...Even if you seldom go off road...a lifted Taco with 35's just looks awesome! IMHO
  12. Mar 27, 2012 at 6:32 PM
    fj6high
    Howard
    Tarpon Springs
    07' Fjcruiser
  13. Mar 27, 2012 at 7:05 PM
    Large
    Large Red
    Any lifted taco, whether it be 2.5, 3, 4, 4.5, 6" so on & so fourth and a knowledgeable driver doing the wheeling should have no issues off roading, the opinions on here are all mainly biased.
