Suspension upgrade experience?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco Ivz, Feb 14, 2021.
  1. Feb 14, 2021 at 1:08 PM
    Taco Ivz
    Taco Ivz [OP] Member
    19 taco pro
    Hi,
    I have question in regards to suspension.
    Truck- 19 tacoma pro with camper and roof rack.
    Problem- bed sag from weight of camper. Leaf springs almost flattened.
    Solution was to replace leaf pack with a deaver stage 1.
    Concern of possible extreme rake.
    Don’t want to put a spacer in front.
    I like the ride of the stock fox.
    Wouldn’t mind a little more lift.
    Has anyone upgraded to the fox 2.5 coilovers dsc w/ rear shocks ?
    If so, how is the ride compared to the stock pro’s and at what height did you go up to?
    Thanks in advance
  2. Feb 14, 2021 at 1:36 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    You could put a 3 leaf add leaf in the back, very affordable.
    71tattooguy and whatstcp like this.
  3. Feb 14, 2021 at 1:49 PM
    Taco Ivz
    19 taco pro
    Thanks for the advice
  4. Feb 14, 2021 at 2:05 PM
    Grossomotto
    2017 4WDV6LB6MT
    If you don't do serious off roading, your fronts are probably still good. If you do go the 3 AAL leaf route and already taking apart your leaf packs, you can find almost new stock leafs for nearly free locally. A lot of members take them off new trucks and have them sitting around.
    I know I didn't answer your question about the fox upgrades, but I'm biased since I'm mainly on pavement.
