Suspension upgrade for hauling question
Discussion in 'Suspension' started by utmck, Dec 11, 2010.
  1. Dec 11, 2010 at 12:24 PM
    utmck
    utmck [OP] Active Member
    I own a 2006 DC 4x4 TRD Sport non TSB
    All of my driving is on pavement, but I am going to be purchasing a RV this spring and was wondering what "improvements" do you suggest I make to the suspension. I want to keep the ride "comfortable" and stable and also be able to handle a 6,000 lbs. RV.
    Thanks.
  2. Dec 11, 2010 at 12:40 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    u may want to get an AAL put in or put in a set of Air bags to maintain a decent ride height and not have it squat so bad. also ive heard of people puttin in Timbren bumpstops when hauling alot to prevent bottoming out.
  3. Dec 12, 2010 at 5:12 AM
    utmck
    How much would AAL add in height? How would they affect the ride quality? Would I then need to get a set of 5100's and adjust them to make the truck sit even? If so, how much adjustment would it probably require and can you adjust after install?
    Thanks.
  4. Dec 12, 2010 at 6:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Peronally, I wouldn't go with an AAL. If you're hauling regularly, that AAL is gonna sag or break eventually.
    Do some research on aftermarket replacement leaf paks, helpers springs, & airbags.
