Suspension Upgrade, no lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jaragon, Jan 23, 2024.
  1. Jan 23, 2024 at 6:48 PM
    Jaragon
    Jaragon [OP] Active Member
    22 TRD Sport - Lunar Rock
    Skid plate for oil changes Cat shields for theft Snail Armor and pop lock tailgate LEDs and custom Inferno accents inside
    Oh no! I must have intruded on your private little fantasy truck land. I hope you don't get all upset that we can actually like the same things.
    I didn't say it compare my roads to anyone else's.
  2. Jan 23, 2024 at 6:49 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. Jan 23, 2024 at 7:23 PM
    TacoTuesday1
    SD CA
    Jaragon[OP] likes this.
  4. Jan 23, 2024 at 8:09 PM
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC Bilstein 6112/5160 Icon RXT Rock Sliders
    To get things back on track…
    … I went with 6112/5160’s from @memario1214 and I think they are incredible. The digressive piston helps them corner and handle really well (much better than stock TRD OR), but when I big hit happens it absorbs it much better as well.
    where they feel stiff is the small bumps in the road. The stiffness for good handling means some of the small cracks are felt more than other suspension options.
    big bumps like a pothole or a large G out bump on the freeway are handled really well by these, and it’s worlds better than stock.
    hotshot also sent them to me assembled and ready to bolt on, and were great to work with.
  5. Jan 23, 2024 at 8:25 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Eibach makes the springs that are used on many of the high end sets of coilovers available for these trucks. They're are one of the largest suspension companies in the world and are very well versed in these trucks lol. If your friend has their suspension and does not like it I would 100% assume they're the stage 1. Those ride terribly, however their stage 2 is much more comfortable than the 6112's and allows for ride height adjustments without being removed from the vehicle. For how smooth the stock OR suspension is I'm surprised how much stiffer the 6112's are. I would like to try their 8112's though, those look pretty trick. But of course YMMV based on the weight and needs of your truck and the rest of your setup.
    That said, I run custom tuned ADS shocks (that use Eibach springs) and love them to death. Just trying to give the OP some additional options to consider.
    Also fwiw I ran the Icon RXT's for a while and can confirm that they ride way too stiff if the bed is unweighted (which is my case 99.9% of the time) and they were 10000x more uncomfortable than stock. I could not get rid of them fast enough. Very happy after switching to the J66 packs instead, as are many others who have made the switch. If you do carry a couple hundred extra lbs in the bed at all times though, the RXT is a completely different pack and rides much more comfortably than unloaded.
  6. Jan 24, 2024 at 8:22 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    I have used several
    The takeoff TRD OR setup install does soften the ride on a Sport, but you introduce nose dive during hard braking.
    if you do not need a front lift capability, Bilstein 4600 are a less expensive alternative to 5100 shocks with the same ride quality.
    https://academy.bilsteinus.com/knowledge/4600-versus-5100#
    usmc2msu and Jaragon[OP] like this.
  7. Jan 24, 2024 at 9:59 AM
    gen2eng
    gen2eng Well-Known Member
    Indiana
    2022 TRD Offroad DC 4x4
    Thanks for the details... question. I'm still stock but looking at the same setup... higher speed fun over pothole free, but very uneven chip and seal county roads. Any experience with your setup bottoming out and hitting the rear bumps hard with 2 adults in the back over mild"ish" bumps or tracks at 50ish mph? Sorry, a little specific. Deciding if I need to supplement with a leaf spring tweak or sumo stops.
  8. Jan 24, 2024 at 10:58 AM
    chasecmc
    Chase
    2017 DCSB TRD OR
    I don’t have mine set up at stock height. I actually have an icon RXT leaf pack at option three in the rear. I have a go fast camper and rock sliders on the truck all the time though, and it handles the weight really well. With my set up I would absolutely not bottom out with that weight, but you might with the stock leaf pack.
    Jaragon[OP] and gen2eng[QUOTED] like this.
  9. Jan 24, 2024 at 2:51 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  10. Jan 24, 2024 at 3:49 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My ride improved big time from the oem OR shocks to the 5100's. set @ 2".
    If 2" scares some people, I highly recommend setting the 5100's up front to 1" and leaving the rear height stock.
    Jaragon[OP] and Mac62989 like this.
  11. Jan 25, 2024 at 2:02 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have been on 5100s for close to 6 years, different settings and now on the 5th perch. Ride never changed but does ride best on the 5th to me but I think its because on the new 285s from Toyo. The ride is a lot smoother than the stock Sport shocks and my family member had a 20 Off Road which rode nice but too mushy feeling for me and he now has a 23 Pro which rides great. I think the 5100s are a great shock and compared to his new Pro with the Fox shocks I think the 5100s are just slightly more harsh riding but in a good way.
  12. Jan 25, 2024 at 9:32 AM
    gen2eng
    Indiana
    Thanks!
  13. Jan 25, 2024 at 5:44 PM
    Jaragon
    That was a very interesting read, thanks.
  14. Jan 25, 2024 at 7:52 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    TRD Pro suspension is designed to work well offroad while also riding well onroad. The shocks have an internal bypass one that lets them absorb smaller bumps on road before the firmer damping for larger travels in the suspension engages. I ran it on my Pro for two years before upgrading to another setup from Fox, and the only downside I felt was that you get a good deal of nose dive on harder braking due to the softer bypass zones at ride height, they handled rough pavement and potholes great IMO and were totally capable of going over speed bumps way faster than one was supposed to.
    Fox gives the rebuild interval as 50K miles but if you aren't hammering on the shocks offroad per milage a lot they should definitely go a lot farther than that. Note that they have about 1" front lift so the truck is closer to level than other stock setups (but still a bit higher rear than front)
  15. Jan 25, 2024 at 8:31 PM
    #35
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    hmmmm, I am wondering where in the US of A you live? My little town it is better to ride in the ditch half the time.
  16. Jan 25, 2024 at 8:53 PM
    #36
    gudujarlson
    Minnesota
    I currently live in St Paul where the spring thaw brings shattered roads. We have two seasons in Minnesota: winter and road construction. Before that I lived in rural southern Minnesota (Midwest farm country) where a vast majority of roads are gravel. We tend to have effective governance here and I rarely complain about the roads.
  17. Jan 25, 2024 at 9:07 PM
    #37
    CaptainBart45
    Bart
    Work in progress...
    I get it, I do. When we drive up to Flagstaff in the spring I expect to loose a windshield to a cinder rock or a tire to a pot hole. But here in Southern California the roads have 100 percent gone to shit and we are taxed to no end to pay to improve them. I am tire of the shit, I am. ....good night Jim Bob!
  18. Jan 25, 2024 at 9:32 PM
    #38
    gudujarlson
    Minnesota
    How many other parts of the country have compared your local roads too?
    I’ve been to LA, the Bay Area, Austin, Seattle, Phoenix, Denver, and other places. The roads were fine. No competition with crap ass spring roads in Minnesota.
    CaptainBart45 likes this.
  19. Jan 26, 2024 at 7:09 AM
    #39
    CaptainBart45
    Bart
    Work in progress...
    I a going to be quiet because I am off track on this subject.
  20. Jan 26, 2024 at 8:17 AM
    #40
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    Do you have the photos from your review still by any chance? They dont seem to load in your linked review. It's something i wouldn't mind doing to tame down the rear end shimmy.
