Suspension upgrade noob... having steel bumper installed, and want a moderate lift - some questions
Discussion in 'Suspension' started by DaveCanuck, Jan 6, 2019.
  1. Jan 6, 2019 at 5:57 PM
    DaveCanuck
    DaveCanuck [OP] Well-Known Member
    Dave
    Canada
    2011 SR5 V6
    My truck is a 2011 access cab with a canopy, having a Demello 3 hoop bumper installed, it's probably 120 lbs.
    I'd like to go for a moderate lift, probably 2". Stock shocks + springs in the front, and a recently replaced set of Toyota leafs in the back (recall), and stock shocks. I almost never go off road, unless it's for camping, and in those cases it's logging roads.
    I'm leaning toward OME springs + shocks in the front, but have some questions about options:
    A lot of people seem to rave about Billsteins (usually 5100's), but I'm wondering do they pair well with OME springs?
    How does the Toytec and Icon stuff stack up against Billstein and OME?
  2. Jan 7, 2019 at 10:14 AM
    JDEMELLO
    JDEMELLO Well-Known Member Vendor
    Corona Ca
    none
    The OME and Bilstien IMO are very similar in what they are and what they do. If it were me, I'd go with the bilstiens.
    Toytec and Icon are a different league of suspension. Depending on the toytec kit it's a good bridge between the OME and the Icon's. Icons are more comparable to kings, fox's and other coil over brands.
    If they were cars. The OME/bilstiens would be a Camry, reliable comfortable but nothing you want to brag about to your friends. Toytec would be Like a subura WRX, cool car but at some point you have to grow up and get a big boy car. Icon/king/fox are like a corvette you are now full blown into your midlife crisis and chics will throw them selves at you on the trail. Long travel is like a Harley, you can be fat, ugly and horribly disfigured but you are still the coolest kid on the block.
    Hope this helps:)
  3. Jan 7, 2019 at 1:20 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    What springs would be appropriate with the Billstien 5100's?
  4. Jan 7, 2019 at 4:05 PM
    JDEMELLO
    Corona Ca
    none
    You could do stock or maybe a icon expansion 3 leaf pack. either would work.
  5. Jan 7, 2019 at 4:13 PM
    Ossaris
    Ossaris A Bad Person Doing Good Things
    Aliens
    SoCal
    2016 TRD OR 4x4 w/ 6112s & 5160s
    Lights for days! Sasquachified!
    Byfar the best description for this I have ever seen! I love it!
    JDEMELLO[QUOTED] likes this.
  6. Jan 7, 2019 at 4:21 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    How about for the front springs?
  7. Jan 7, 2019 at 4:24 PM
    Ossaris
    Aliens
    SoCal
    Expand your question. What do you mean?
  8. Jan 7, 2019 at 5:01 PM
    JDEMELLO
    Corona Ca
    none
    I'm going to assume you mean OME springs. I'd go with mediums, anything more and it will ride like a pogo stick. Our bumpers aren't that heavy and the majority of the weight is kept closer to the front axle so the leverage effect is lessened.
  9. Jan 7, 2019 at 5:07 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    A different opinion here..
    I wouldn't say they pair well. It is true you can run them with OME coils, but it is not recommended to run OME coils on 5100's at anything other than the lowest notch/setting. Especially 886 coils if you are running heavy weight up front. For 886's I would recommend springing for OME shocks. The billies will wear faster and ultimately fail in that configuration.
    OME coils and shocks are meant and designed to work together.
    Bilsteins are good if cost is a concern. They are cost effective.
    All that being said, I currently run OME in the front and Bilsteins in the rear..for now...
  10. Jan 7, 2019 at 5:30 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    Ok, good so far...
    Jason Demello, what halogen fog lamps are recommended with your bumpers? That's the last Missi g piece before installation.
  11. Jan 9, 2019 at 11:15 AM
    JDEMELLO
    Corona Ca
    none
    We use and recommend Baja designs. Other 3-4in lights can fit but we like baja designs.
