Suspension Upgrade Question?
Discussion in 'Suspension' started by JRFugitt, Oct 25, 2012.
  1. Oct 25, 2012 at 9:52 PM
    JRFugitt
    JRFugitt [OP] Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    I have a '13 stock PreRunner and am not interested in lifting the truck, but I am curious about the 5100's for the rear. How do they give you a better ride? Is it the valving or longer travel.....? Also does anyone make a more progressive multi leaf spring pack (aka. alot more leafs?). Would this give more load capacity and still ride better than stock with maybe and inch of lift or so?:notsure:
  2. Oct 25, 2012 at 9:56 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    The valving give it a better ride IMO
    They have better leaf packs out there, But if you only want 1 inch of lift, you will have to use an aal.
    dakar leaf packs are great, but they give more of a lift than 1 inch
  3. Oct 25, 2012 at 9:56 PM
    acdronin
    acdronin Well-Known Member
    They absorb better than the stock, as for the leaf pack, the creme de la creme would be a custom pack from Alcan, not cheap but probably the best
  4. Oct 25, 2012 at 9:58 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Yes I would agree with alcan, But the OP is looking for one with a 1 in lift. I dont know of any exept an aal that would do that
  5. Oct 25, 2012 at 9:59 PM
    acdronin
    I called Alcan and asked them, they can build him leafs with any lift or no lift at all
  6. Oct 25, 2012 at 10:00 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    ok. I stand corrected:D
    thank you
  7. Oct 25, 2012 at 10:21 PM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    Thanks for the quick responses, good advive.
  8. Oct 25, 2012 at 10:25 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    good multi leaf progressive AAL = icon 3 leaf or wheelers 3 leaf AAL's, they are both the same IIRC and add like 1.5" without the OL leaf. i love my wheelers 3 leaf with the fox shocks.
  9. Oct 30, 2012 at 9:22 AM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    How about some opinions on:longer stainless steel brake lines,
    bump stops,
    u-bolt flip kits,
    shackle flip kits and anything I missed.
    I will be getting bilstein 5100's all the way around and a custom leaf pack but with little to no lift, I figure the shackle kit and or the leaf pack will be around 1 inch or so don't want to go much higher.
  10. Oct 30, 2012 at 10:45 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    You cant flip the shackles on the 2nd gen tacos
  11. Oct 30, 2012 at 11:04 AM
    acdronin
    You won't need longer brake lines if you plan on keeping the stock height and suspension travel.
  12. Oct 30, 2012 at 5:47 PM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    Oh ok, thanks Nick.
  13. Oct 31, 2012 at 7:26 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    no problem. You may need to do a u bolt flip depending on your leafs as well
  14. Oct 31, 2012 at 8:20 AM
    acdronin
    Actually a couple of people are working/developing flips for the second gens.
  15. Oct 31, 2012 at 8:21 AM
    acdronin
    Why would he need to flip the u-bolts?
    He will probably need longer ones anyways and having new ones is always recommended.
  16. Oct 31, 2012 at 10:17 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
  17. Nov 1, 2012 at 6:23 AM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
