Suspension upgrade ?'s
Discussion in 'Suspension' started by Fox2011PM, Jan 20, 2012.
  1. Jan 20, 2012 at 8:52 PM
    Fox2011PM
    Fox2011PM [OP] "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    I currently own a 2011 DCSB with the off road package. I bought it with a 1.75" spacer up front and a 2" block in the rear. I like the way it sits and drives but am looking to do away with the spacers and blocks and achieve a more level stance but obtain about a 2.5" lift but no more than 3". Also, I do not want to have to upgrade alot of other components such as a diff drop kit or axle shims unless absolutely necessary. I will be doing minor off road trips but I am looking mainly for the stance and "look" and maintain a great on road drive. I would like to possibly stay with the stock UCA's unless I absolutely have to swap them (and probably will down the road). Now for the ?'s-- My first is, can I use my stock coils and with Billstein 5100s front and rear, and do away with my spacers and blocks? Will this give me the lift and level stance I am looking for? Second-- If I need to replace my coils (with say the Eibach's) can I still do away with the spacers and blocks?
    Or scrap the first 2 questions and just go with the OME 3" lift from Toytec? and will the OME give me ALL the things I am looking for? Sorry for the lengthy post, just want the best look, performance and bang for my buck. Thanks to all that respond!
  2. Jan 20, 2012 at 11:59 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Getting TSB done also, forgot to add that in there
  3. Jan 21, 2012 at 12:16 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Yes, you can use the 5100s with stock coils, the lift function was designed to be mated to stocks. You don't get lift from the rear 5100s. If you set them to 2.5, you shouldn't need new ucas, though any lift has its variables.
    If you use coils or 5100s, you can get rid of your spacers.
    If you want a full 3" though, either the toytec or ome will give you a good bang for your buck, and you don't have to worry about buying parts; you just buy the whole kit.
  4. Jan 21, 2012 at 1:37 AM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Thanks Konaborne, any input helps. May just go with the 5100s all the way around and leave my blocks in back, with the TSB, and front set at 2.5 that should get me pretty close to level....right? I believe the TSB gives you like .5"?----ALOHA
  5. Jan 21, 2012 at 1:41 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    You should be leveled pretty good, you could also switch out your block for an AAL, it'll extend the life of your leaf pack (blocks can wear down packs faster)
    the 5100s set to 2.5 up front might ride a little stiff/you'll lose some travel, but if you don't offroad much it shouldn't be a problem. the 5100's ride way better than stock
  6. Jan 21, 2012 at 1:45 AM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    So 5100s set at 2.5 and 5100s in the rear, TSB added, block removed what AAL do i need? And if I don't go with the TSB what do I need as far as an AAL? How do those come and where is the best place to snag some? Sorry for all the rookie ?'s
  7. Jan 21, 2012 at 1:50 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    the AAL is up to you, many people make them, ranging from 1-2" (usually)
    toytec, skyjacker, Icon, all make AALs (just need to make sure they're TSB-compatable if you get them, just call the distributor and they should be able to tell you)
  8. Jan 21, 2012 at 2:05 AM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Man I can't thank you enough for the quick response and info! Stay safe
  9. Jan 21, 2012 at 2:11 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    no problem! :thumbsup:
    obligatory :worthless: when it's installed! :D
  10. Jan 21, 2012 at 2:44 AM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Pics definitely forthcoming when installed...gotta show her off right?!!!
  11. Jan 27, 2012 at 1:03 PM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    look in my gallery...Just got it done today. Ride is good no complaints and got about an inch lift in the rear with a free alignment.
  12. Jan 27, 2012 at 5:19 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Prob better off with new coils too......otherwise theyll ride just like a spacer lift! You have new coils so they'll be OK for a little bit but you'll eventually have to do it again with new coils. Just some food for thought! I was in the same boat when I ditched my spacer lift and decided the new coils were needed too!
