Suspension upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trout49, Feb 26, 2021.
  1. Feb 26, 2021 at 7:51 AM
    Trout49
    Trout49 [OP] Member
    Tim
    2013 Tacoma
    3 “ lift custom bumpers, vagabond drifter shell, solar powered, dual batteries, goose gear interior. Dometic fridg.
    I have 2013 tacoma. I now have Vagabond outdoors camper. I did add an extra leaf spring. I am still bottoming out a little and floats like boat on the freeway, had a lift done and they used toyotec shocks all the way around (3 years ago). How do you determine what you need for the extra weight. Camper weights 350-370 then with all my crap in side its about 600-700 lbs.
    Thanks,
    Tim
  2. Feb 26, 2021 at 8:43 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’d replace the entire leaf pack in the rear with a minimum 600lb constant load pack.
  3. Feb 26, 2021 at 9:10 AM
    Trout49
    Trout49 [OP] Member
    Tim
    2013 Tacoma
    Any recommendations for new leaf springs.
  4. Feb 26, 2021 at 9:34 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I took my 2013 to a spring shop and had two more leafs added. It made the ass end so high I had to put a 2 1/4" lift in the front to level it. Very little squat now even with 1000 lb tongue load.
  5. Feb 26, 2021 at 10:52 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    You could look into air bags
  6. Feb 26, 2021 at 10:53 AM
    SunsetDiesel
    SunsetDiesel Well-Known Member
    Devar/ dakar always recommend here. Deaver can make you a custom pack for your exact weight.
  7. Feb 26, 2021 at 10:54 AM
    SunsetDiesel
    Love the air bags on my f250. Not sure how the taco would handle them at pressure. May throw you all around the road.
  8. Feb 26, 2021 at 11:08 AM
    Not a golfer
    Calgary, Alberta
    Not sure about the ride quality but I'm looking into them. I carry a far amount of weight in tools and equipment for work so my truck does sit a little low.
  9. Feb 26, 2021 at 11:27 AM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    Give alcan springs a call. They can make you springs custom for your set up.
  10. Feb 26, 2021 at 10:45 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    I have Firestone Ride Rite air bags on my truck and run 10 lbs psi with no load and it rides fine.
  11. Feb 26, 2021 at 10:57 PM
    Shupper35
    Shupper35 Member
    Zanen
    2005 Tacoma
    Mid travel etc
    I would go get deaver springs
