Suspension upgrade
Discussion in 'Suspension' started by Hauser94, May 16, 2023.
  1. May 16, 2023 at 8:13 AM
    Hauser94
    Hauser94 [OP] Well-Known Member
    2016 Black Tacoma SR5 DCSB
    Hello I’m looking for a 1.5 inch lift all the way around. I’m looking to upgrade suspension for comfort mainly. What is the best option for me.
  2. May 16, 2023 at 8:20 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    What's your budget. 500$, or $20k? On road, or off road. if both, how much of each? 50/50, 75/25? Lots more info would be good on your use case.
  3. May 16, 2023 at 8:31 AM
    Hauser94
    Sorry. Never offroad, pavement only. Just looking for a more comfortable ride on the road. Budget 2k
  4. May 16, 2023 at 8:35 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    OEM TRD Pro fox take offs are the best ride IMO. Toyota spent a lot of R&D with Fox to dial them in. Depending on the year it will add 1.5" lift up front and then I recommend an icon rtx add a leaf.
    Ricardo13x likes this.
  5. May 16, 2023 at 8:41 AM
    Hauser94
    Word do you have a part number for the Oem fox’s?
  6. May 16, 2023 at 8:43 AM
    YF_Ryan
    Kent, WA
    jsut look for OEM Fox TRD Pro Tacoma on FB Marketplace or Craigslist
    If this link works, it's an example.
    Hauser94[QUOTED][OP] likes this.
  7. May 16, 2023 at 8:48 AM
    Bishop84
    Bishop84 Well-Known Member
    Bilstien 6112 / 5160 combo is effectively the old pro setup and works well as a mild lift and improvement of ride.
    You'll need new rear leaf springs, add-a-leaf only really works on new, so you'll need to start down that rabbit hole as well.
    memario1214 and YF_Ryan like this.
  8. May 16, 2023 at 8:55 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Do you have any additional weight on or in the truck? Armor of any kind, bed racks, tool boxes?
  9. May 16, 2023 at 9:05 AM
    Hauser94
    No nothing, no extra weight at all, adding the oem skid plate thats it
  10. May 16, 2023 at 9:06 AM
    Hauser94
    Can you elaborate on the second half of that. AAL only works on new?
  11. May 16, 2023 at 9:11 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    If there was ever a more subjective term, I do not know what it is. Can you help me understand what you mean by "comfort"? My definition of a comfortable ride is a stiff suspension - I cannot stand squishy rides. That is me though. What is it about the stock suspension that you find uncomfortable? This may help with the community's suggestions.
    madcratebuilder likes this.
  12. May 16, 2023 at 9:13 AM
    YatYas1833
    YatYas1833 Well-Known Member
    22 WHITE TRD OFFROAD 4x4 DCSB
    King 2.5’s with adjusters from accutune front and rear, 88 rotors rear add a leaf, Camburg X-joint UCA’s, Factory style trd pro 16” wheels with 0 offset, 285/75/16 KO2’s, pro grille, Front bumper viper cut, trd front skid plate, full RCI under skid plates, Cali raised trail sliders, exhaust cut dump, KDMax 10.0 tune
    I’m not sure if I would go with this option. Trd pro take offs are usually over priced for what they are.
  13. May 16, 2023 at 9:13 AM
    Bishop84
    So leaf springs rely on curve, they fatigue and flatten over time.
    When an add a leaf is placed, it assists and works with the other springs to retain curve and height.
    If the factory springs are worn/flat, the curved add a leaf takes most of the weight and will act as a lift for a short term, then will flatten very quickly.
    YF_Ryan likes this.
  14. May 16, 2023 at 9:17 AM
    memario1214
    Colton
    Missoula, MT
    Okay so in your case I would probably agree with @Bishop84 that a good "maintenance-free" setup would be something like the Bilstein 6112 up front paired with Bilstein 5100 or 5160 out back. They ride well for lifted applications, and don't ask for a rebuild every couple of years. If you're okay with pulling shocks off and rebuilding every 2-3 years then I would probably say to go with something like a Fox 2.0 setup front and rear.
    As for the rear lift situation I would guess you're only asking for 1-1.5" of rear lift to be level or slightly maintain rear rake. I fly in the face of many others' recommendations when it comes to rear lift scenarios. Sure, your leaf packs are probably not still spring chickens (no pun intended), but unless you tell me that you tow or load down frequently they're probably "ok". You can probably get away with getting your small rear lift by way of a small block out back, and then just be off to the races.
  15. May 16, 2023 at 9:29 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Hey @Hauser94 Just an another vote for what @memario1214 Colton is saying. He’s helped many a member here and I’ve heard nothing but good things from his shop.
    I’ve got the Ironman Foam Cells, but you saying you want a comfy ride knocks them out of the running. They are a great lift but paired with E rated tires makes them a little stiff. Could also just be feeling the bumps through the tires I’m feeling and not the suspension.
    Hauser94[OP] likes this.
  16. May 16, 2023 at 9:29 AM
    Bishop84
    People need to start peaking at a lot of factory trucks, many many of them have leaf blocks oem. Even the TRD kit has it. Same ride, slightly higher. Just need a longer shock, done.
  17. May 16, 2023 at 9:33 AM
    Hauser94
    I feel like i bounce a lot in my truck not like crazy but I do feel a lot of bounciness when going over mild bumps in the road. So I guess I’m looking for something a bit stiffer?
    mic_sierra[QUOTED] likes this.
  18. May 16, 2023 at 9:36 AM
    Hauser94
    Thank you for the thorough response. I am a complete rookie in the lift game. Can you explain to me the difference of lift vs suspension. I was under the impression that adding bilsteen 5100 or 5160 in the back is lifting the rear. Why rhe need for a block or leaf pack?
  19. May 16, 2023 at 9:54 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    ‘Because the rear shocks do not provide lift. Rear lift can be provided by the rear leaf springs or by adding a block under the spring.
    On the bottom, OEM leaf pack with 1.5 “ block. On the top OME replacement.
  20. May 16, 2023 at 10:06 AM
    Hauser94
    Which is better out of the 2, a whole new leaf pack or bloc?
