Suspension Uprgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jdog728, Jan 30, 2025.
  1. Jan 30, 2025 at 10:37 PM
    Jdog728
    Jdog728 [OP] Member
    2022 White Tacoma TRD Off-Road
    3 inch lift front 2 inch rear currently running stock rims and tires
    Hey guys, so a while ago I made the mistake of caving in and going with the rough country 3 inch lift (image in this post) and have also put around 15k miles on them. I think this spacer that I have on top is killing my coils as well as my UCA. I think going to these Eibach shocks and coil-over would be much better for the truck and would have a smoother ride, thoughts?
    Also if I were to go with a suspension kit such as this would I really need to get these rear shocks when I have the RC ones that work well. The rear consists of the 2 inch block and shock. I really don't wanna kill my wallet, truck is a daily driver as well as overlanding. Also one big question I have is, after looking at my coil, is compressed to the point where it is "damaged", can I just get the billstien 5100 and put these coils on there or is that a no?
    Thanks guys! Please give all the feedback you want, the more knowledge I have the better!
  2. Jan 31, 2025 at 8:57 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Personally I wouldn't put anything more than a 1" block in the rear. Do you find the rear end bounces around too much with the 2" block?
    I'm quite content with my 2/1" Bilstein 5100 setup, and can fit 33" tires. If I had more money, I'd move up the Bilstein Family, but that's just me.
    Lots of love for the 5100s on Youtube
  3. Jan 31, 2025 at 11:35 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I'm not a fan of blocks because of the "axle wrap" thing. 5100 are very popular for good reason - they are great shocks for the price and pretty much fine for most applications - if you are not desert racing or jumping your truck or doing extreme rock crawling 5100 will be fine on and off road. Are the higher quality "better" suspensions ? Sure - but do you really need them - probably not. That Pro-Truck Lift kit stage 1 looks really good. BTW the only complaint I have ever heard first hand about 5100 is that they tend to fade after hours of hard use. Personally I have not had that experience but I have not actually used my truck with 5100s for more than say 3 or 4 hours at a clip - I mean I have been on some trails all day but never say for 6 or 8 hours straight with out a break(s) so I have not experienced said fading.
