Suspension while towing
Discussion in 'Towing' started by Oxbow, Mar 27, 2013.
  1. Mar 27, 2013 at 8:47 PM
    Oxbow
    Oxbow [OP] New Member
    USA
    04DC4WD
    None
    Hi there, this is my first post on this site , would like to say this is such a great site. Well I have a 2004 DC 4wd with the 3.4, was wondering I tow a boat that ways around 2700 lbs my rear sags a little any ideas on leveling the rear end when towing the boat? Was also wondering if it would've good to turn the over drive off while towing the boat?
  2. Mar 27, 2013 at 8:52 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
  3. Mar 27, 2013 at 9:47 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    OD off if your truck is searching for gears...
    To being up the rear while towing, get airbags. An Add-A-Leaf will level you while towing, and lift the rear when empty. Air bags can also be adjusted depending on how much weight you have behind you...
