suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackyota, May 17, 2012.
  1. May 17, 2012 at 5:41 PM
    blackyota
    blackyota [OP] Member
    Corey
    Lugoff, South Carolina
    05 tacoma, ext cab
    brush guard, billiet grill, 33s nitto trail mudders, leveling kit, 3in body lift
    I was wondering what i can do to make my truck ride better off road... i have a leveling kit and then a 3" body lift. It still has the stock springs, and shocks. the truck rides great on road, but once i turn down a rough road... boy hold on. any suggestions???
  2. May 17, 2012 at 5:49 PM
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    I'd suggest scrapping the body lift and leveling kit (sell it on Craig's list or here) and get something like this:
  3. May 17, 2012 at 5:50 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Remove sway bar? The sway bar makes your front suspension work as one unit, which is great on the highway...it minimizes body roll and helps prevent a roll over at highway speeds. But off-road, it SUCKS. Taking it off will allow your suspension to drop and rise truly independently of the other wheel, therefore minimizing "the bobblehead effect"
    EDIT: Just saw you have a body lift...yeah get rid of that first. lol
  4. May 17, 2012 at 5:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    What's your budget OP ?
  5. May 17, 2012 at 6:08 PM
    blackyota
    Corey
    05 tacoma, ext cab
    ok so the body lift is having some to do with this then... correct me if im wrong. i went with this set up a few years ago... and i think its time to make a change.
  6. May 17, 2012 at 6:10 PM
    blackyota
    Corey
    05 tacoma, ext cab
    irish020 that is a 3" suspension lift? cuz i have the nitto 33 x 12.50 on the truck. originally i had just a leveling kit, the previous set of mud tires rubbed like crazy. i couldnt even park.
  7. May 17, 2012 at 6:28 PM
    Irish020
    Phil
    Pennsylvania
    Yes, 3" lift...those are 285/75/16's BFG AT KO's, had to lose the mud flaps and just a smidge of grinder work on the inside of the fender..this was install day to give you an idea of the difference....
  8. May 17, 2012 at 7:16 PM
    blackyota
    Corey
    05 tacoma, ext cab
    as far as buget... 1000 at the most. i would have to save for awhile. haha
  9. May 17, 2012 at 7:19 PM
    blackyota
    Corey
    05 tacoma, ext cab
    ok this might sound like a dumb question, but how could i get it back to stock when i have added the body lift. i mean i would have to get back all the factory size bolts, brackets, etc....???? cuz it has been yrs since i did the lift. and i have no clue where all those parts are.
  10. May 17, 2012 at 7:21 PM
    blackyota
    Corey
    05 tacoma, ext cab
    i would have to take awhile to save up that much... i have some to spend now, but would that be enough to make the switch?
  11. May 18, 2012 at 3:27 AM
    Irish020
    Phil
    Pennsylvania
    For the setup I showed you, the $1000 won't get you the new UCA's which makes a huge difference in drivability and alignments....
    Look around in here, you'll find reasonable options for under $1000 that would improve your off road capabilities!
