Suspension
Discussion in 'Suspension' started by Mohilo, Feb 14, 2020.
  1. Feb 14, 2020 at 1:19 PM
    Mohilo
    Mohilo [OP] Member
    Colorado
    2018 Tacoma limited
    Off road tires,
    Ok I'm getting ready to order from Rough Country a 4" lift and suspension kit for my 2018 tacoma limited. Is it a good idea?
  2. Feb 14, 2020 at 2:28 PM
    DC5275
    DC5275 Well-Known Member
    David
    Nature Coast Hernando, FL
    2017 Tacoma TRD OR DCLB Black 4.88 Gears
    Are you installing this or having it installed?
    If you are having a shop do the install, I noticed you are in CO. If you are near Castlerock area. Stop in and talk with Andrew at Altitude Offroad and discuss other options that will meet your end goal.
    If not call Headstrong Offroad, AccuTune Off-Road and discuss your options for your desired end results.
    If you understand the pro's vs con's of a lift of this type lift.
    If this is your must have lift. Then you have your answer.
    If this is a Friday thing, I'm sure it will begin...
    GL
