SW PA/Pittsburgh and wherever camping, wheeling and beer trips
Discussion in 'North East' started by disconnected, Jan 10, 2020.
  1. Jan 18, 2021 at 7:05 PM
    #621
    condortaco
    condortaco Well-Known Member
    Bob
    Saltsburg, PA
    '03 Tacoma TRD
    Maybe 6 inches.
    Loco_Driver likes this.
  2. Jan 18, 2021 at 8:06 PM
    #622
    Loco_Driver
    Loco_Driver Well-Known Member
    Connellsville, PA
    2018 TRD OR DCSB M/T
    Loco Driving Mode
    I’m game also
  3. Jan 19, 2021 at 2:33 AM
    #623
    PlatinumCloud
    PlatinumCloud Jameson Drinker
    Sarver
    2015 off-road pkg
    I always figure your in...like crack to a druggie.
    Loco_Driver[QUOTED] likes this.
  4. Jan 19, 2021 at 3:57 PM
    #624
    Loco_Driver
    Connellsville, PA
    Loco Driving Mode
    I guess you caught on...
  5. Jan 19, 2021 at 3:57 PM
    #625
    Loco_Driver
    Connellsville, PA
    Loco Driving Mode
    Let me also add that like many of us, I'm stuck at home for work so I itch to get out as much as possible.
  6. Jan 19, 2021 at 4:13 PM
    #626
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Thanks for the motivation @PlatinumCloud. That was fast. Now to find the time to install. Hopefully this weekend.
  7. Jan 20, 2021 at 11:26 AM
    #627
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  8. Jan 20, 2021 at 3:09 PM
    #628
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Love to see you out this way Craig. I've yet to see your rig in its own element.
  9. Jan 20, 2021 at 3:10 PM
    #629
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Hopefully we can put this pandemic shit behind us this year and get back to normal. I miss meeting up with my fellow TW folks! :(
  10. Jan 20, 2021 at 3:15 PM
    #630
    disconnected
    disconnected [OP] LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    Picked this up today, a 70.00 insurance policy!
  11. Jan 20, 2021 at 3:54 PM
    #631
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Get you some primantis
  12. Jan 22, 2021 at 2:43 AM
    #632
    PlatinumCloud
    Sarver
    2015 off-road pkg
    FWIW
    Can tell you from personal experience going through the dozen or so water crossings in WV i didnt have a single drop of water in my diffs...people give horror stories about getting water in their diff and i have no idea how...i changed my rear end fluid after coming home as a couple of people had told me about the rear end is probably full of water....there is so much of a vacuum on the rear end that there no way your sucking water in past the seals. i also did my front diff a month later after wheeling with loco for the first time. no water there either.
    The only way i can see someone sucking water, or getting water into their diffs are from being say in the desert or extremely hot environment and going through extremely cold mountain water and the temp change would cause the seal to not seal due to thermal expansion or the breather failing open. With the way its capped i dont see debris getting into it. Putting a check valve on the rear end makes sense. If you allow the rear end to only push pressure out the rear end will have a "neutral" pressure when at operating temperature. When it cools it will then create a vacuum. thus said vacuum would pull the seals inward thus sealing them even more.
    you can tell Toyota has been around the block on that because from a mechanical standpoint using pressure to help your seals is always better. I also know if the breather was and issue or it didnt function they would have changed it. Toyota knows what people are doing with their trucks.... i can tell you the front how ever does not have a check valve and is run to the firewall.
    Why do i mention all of this? may help someone in the future reading this. if adding breather extensions helps you sleep at night do so. but i can tell you push fitting leak. that tubing is pretty durable and have no doubts about anything made by ARB, BUT keeping things simple is often the best way of keeping things from failing.
  13. Jan 22, 2021 at 2:21 PM
    #633
    PlatinumCloud
    Sarver
    2015 off-road pkg
    Adding to the what did I get for my taco theme we have going on. This is what I’ve got thus far:
    I’m still waiting on my ditchlight brackets, relay holder and rear light mount from rago. I was also able to finally track down a group 35 battery after 2 weeks of searching - this was from the help of a gentleman named John Russo whom is the NE rep for odyssey- highly recommend.
  14. Jan 23, 2021 at 6:32 AM
    #634
    Armyhater458
    Clarion, PA
    2012 TX Pro
    I decided to order new hub assemblies since I'm doing the front brakes anyhow. Not sure how far that'll push the job back, but hopefully it'll save downtime in the future. My hope is to install everything next Saturday.
  15. Jan 25, 2021 at 3:43 AM
    #635
    Loco_Driver
    Connellsville, PA
    Loco Driving Mode
    I think I might have Jiffy Lube change my air filter. It’s just about time to do a little maintenance on the Taco...
  16. Jan 25, 2021 at 5:13 PM
    #636
    Loco_Driver
    Connellsville, PA
    Loco Driving Mode
    When’s the next wheeling adventure?
  17. Jan 26, 2021 at 6:50 AM
    #637
    PlatinumCloud
    Sarver
    2015 off-road pkg
    not sure here. going to be weather and part pending. i also think i may have a bad universal joint.
    if i get parts and its semi poopy out im probably going to putting in batteries and figuring out how im going to cram 5 gallons of wires in to a 4 gallon bucket.
    if its nice and no parts ill probably be game.
  18. Jan 27, 2021 at 6:28 PM
    #638
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Also still waiting on hubs to come. No ship date, but only coming from NJ. I have electrical things I'd like to work out in the near future as well.
  19. Jan 27, 2021 at 9:37 PM
    #639
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Hopefully you didnt order from https://www.jerseybuilthubs.biz/
    He got banned a while ago for taking people's $$
    disconnected[OP] likes this.
  20. Jan 28, 2021 at 2:06 AM
    #640
    PlatinumCloud
    Sarver
    2015 off-road pkg
    Hey like i said at the start; get it going cus once the snow quits flying im headed north.
    i seem to be having the same issues. personal and at work. parts just are not in their same lead time - anywhere. really goes to show you how much shit this country gets from overseas....
    disconnected[OP] and Charlie Too like this.
