Swamped my truck..
Discussion in '1st Gen. Tacomas (1995-2004)' started by _Yota_kid, Jun 18, 2017.
  1. Jun 29, 2017 at 9:56 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Looks like. Long night.
    The anti theft bs was dealer installed. Can be removed. rs4300 system if I do recall. @mechanicjon ??
    As far as what next, what HAVE you replaced, or tested with a multimeter?
  2. Jun 29, 2017 at 10:02 PM
    _Yota_kid
    _Yota_kid [OP] Well-Known Member
    2004 Tacoma 3.4v6 4x4
    I replaced all fuses, fuel filter, spark plugs. That's all I can think of
  3. Jun 29, 2017 at 10:08 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Swap ignition coils to see if misfire moves.
    Get a multimeter and start testing engine sensors. Hope ECU is ok.
    Are you popping any fuses?
  4. Jun 29, 2017 at 10:17 PM
    _Yota_kid
    Ok thanks.
    I have a bad feeling about the ECU..
    No I'm not popping fuses
  5. Jun 29, 2017 at 10:30 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    If it runs your doing good, maybe survived. But there is plenty of sensors. Hope you are cleaning out plugs, and applying dielectric.
    deadhed61 likes this.
  6. Jun 29, 2017 at 10:31 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Could have been worse. I took my 72 Chevy with 4inch lift and 35's swimming. water line tapered from windshield wipers to bottom edge of rear bumper. Luckily I shut the motor off before it took a big gulp.
    So the ECU didn't go under water?
    BartMaster1234 likes this.
  7. Jun 29, 2017 at 10:44 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Possible Igniter or crank sensor or cam sensor. You need to check those plugs for water.
    Marcmtb1 likes this.
  8. Jun 29, 2017 at 10:50 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Have you hooked up a scanner to see what the sensor are doing. What year truck. May have a bad TPS and if its drive by wire that's means a used or new throttle body
  9. Jun 29, 2017 at 11:28 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Wonder if he said "hold my beer" first?
  10. Jun 30, 2017 at 1:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The fact it runs at all is amazing !!!
    Only one misfire code that is all ??
    Water damage to the ECM I am betting it was underwater.
  11. Jul 1, 2017 at 10:04 PM
    _Yota_kid
    It threw two codes. Misfire in cylinder 3 and a heat sensor. I pulled out the ecu today and it looked like water never touched it. I pulled it apart and there wasn't mud or any signs of water so I don't believe it got wet.
    Dalandser likes this.
  12. Jul 1, 2017 at 10:26 PM
    _Yota_kid
  13. Jul 1, 2017 at 10:53 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Swap #3 coil with another cylinder and see if the code moves. Did the motor suck any water into it? Have you done a compression test?
  14. Jul 1, 2017 at 11:03 PM
    _Yota_kid
    I shut the truck off once i knew I was fucked so I don't think it sucked any in. No I haven't done a compression test
  15. Jul 1, 2017 at 11:04 PM
    #35
    mechanicjon
    Jon
    Scottsdale Arizona
    try swapping coils around and see if the misses code changes
  16. Jul 1, 2017 at 11:04 PM
    #36
    _Yota_kid
    Will do. Do you think it could be fuel pump?
  17. Jul 1, 2017 at 11:05 PM
    #37
    mechanicjon
    Jon
    Scottsdale Arizona
    Do you have factory air box?
  18. Jul 1, 2017 at 11:06 PM
    #38
    mechanicjon
    Jon
    Scottsdale Arizona
    Did you drain the tank? Usually a fuel pump works or it doesn't.
  19. Jul 1, 2017 at 11:06 PM
    #39
    _Yota_kid
    No, k&n
  20. Jul 1, 2017 at 11:06 PM
    #40
    _Yota_kid
    Yeah I drained it and put new fuel in
