Swang City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by txtaco87, Jul 8, 2017.
  1. Oct 30, 2017 at 7:59 AM
    #1641
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Make em work. I have faith in youm
  2. Oct 30, 2017 at 8:36 AM
    #1642
    txtaco87
    txtaco87 [OP] Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Lol that would be like stacking two leaf packs.
    MarX and ChadsPride like this.
  3. Oct 30, 2017 at 8:39 AM
    #1643
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    @ChadsPride if you can verify that they will be compatible with your cs047r packs, they are yours.
    The AALs I have are for the el095r packs to make them into the el096r packs (what I have)
  4. Oct 30, 2017 at 8:50 AM
    #1644
    because_wumbo-truck
    Jon
    Houston, Texas
    Time for the Chevy 63 leaf spring mod
  5. Oct 30, 2017 at 8:55 AM
    #1645
    ChadsPride
    Sponsored by TacomaWorld.com
    Thanks a bunch man
    I will have to dig into it a little bit
    MarX and txtaco87[QUOTED][OP] like this.
  6. Oct 30, 2017 at 8:57 AM
    #1646
    because_wumbo-truck
    Jon
    Houston, Texas
    Do it to it
  7. Oct 30, 2017 at 9:23 AM
    #1647
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I have All Pro expo's, they lift 4" & then I added a 2" block. I haven't experienced any issues on or off road.
    On my son's because his money is so tight (he paid for everything) we did an aal & 4" block for now until he can get something better. I don't really like that tall of a block, I feel like it could sort of be a pivot point.
  8. Oct 30, 2017 at 9:40 AM
    #1648
    because_wumbo-truck
    Jon
    Houston, Texas
  9. Oct 30, 2017 at 9:56 AM
    #1649
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    What rear shocks are you running? I have the b110-5100, and extended brake lines already with u-bolt flip and Dakar heavy duty pack for 3” lift
    So I’m assuming a 2” Block would bring the rear somewhat level for me.
    Edit: also, would you recommend the maxtrac 2” blocks from Headstrong that are tapered for pinion angle or flat ones like toytec offers
  10. Oct 30, 2017 at 10:36 AM
    #1650
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I'm running the b110's also & i would go with the tapered block for sure.
  11. Oct 30, 2017 at 10:40 AM
    #1651
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Much appreciated :cheers:
  12. Oct 30, 2017 at 10:42 AM
    #1652
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    No problem! :fistbump:
  13. Oct 30, 2017 at 10:44 AM
    #1653
    because_wumbo-truck
    Jon
    Houston, Texas
    So do you have some serious bro lean right now or are you rubbing on the rear 35s?
    MarX, txtaco87[OP] and ChadsPride like this.
  14. Oct 30, 2017 at 10:53 AM
    #1654
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Tad bro lean, still zero rub in rear with 35s.
    And my headlights blind the shit out of everyone because of the lean
  15. Oct 30, 2017 at 11:35 AM
    #1655
    because_wumbo-truck
    Jon
    Houston, Texas
    How'd you get so much left in the front? 4 inch maxtracks plus 3 inch coilovers?
  16. Oct 30, 2017 at 11:36 AM
    #1656
    ChadsPride
    Yep
    MarX and txtaco87[OP] like this.
  17. Oct 30, 2017 at 11:36 AM
    #1657
    because_wumbo-truck
    Jon
    Houston, Texas
    I wish first gens had nice lift spindles available. I have like an inch and a half to two inches of rake and I just wanna sit level or maybe just have a half inch to an inch of rake at most.
  18. Oct 30, 2017 at 11:37 AM
    #1658
    ChadsPride
    Im sure you can find some
  19. Oct 30, 2017 at 11:43 AM
    #1659
    because_wumbo-truck
    Jon
    Houston, Texas
    I don't think they make em for first gens like at all. I just need to buy some Toytec coils when ever it's time to buy new shocks and go 5100s all around. Right now I have 5100s on stock trd coils and cheap pro comp shocks in the rear
  20. Oct 30, 2017 at 11:44 AM
    #1660
    ChadsPride
    Nice nice - Good time to revamp that puppy then I'd say
