swap OR rear locker for SPORT LSD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Oct 29, 2011.
  1. Oct 29, 2011 at 7:15 AM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    I bought my TRD OR truck a few months ago. It was the only dcsb around that I could find, and I got it for a steal. But after reading here I realize that the LSD of the sport would probably suit my needs better. I will probably never offroad , so the e locker is probably never going to get used.
    I am kind of dumb when it comes to this stuff, but is it possible to simply replace the locker for the LSD? What about just swapping the entire pumpkin?
  2. Oct 29, 2011 at 8:45 AM
    RockRescue
    RockRescue Well-Known Member
    Oregon
    2007 TRD Sport
    The Elocker is a 8 inch rear and the lsd is a 8.4 inch so NO you could not just swap the 3rd member . You would have to swap the complete rear axle assembly .
  3. Oct 29, 2011 at 8:49 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    And then the computer programming would be probably different, because your locker is electronic. LSD is mechanical, so I don't know if you're gonna get error codes....
  4. Oct 29, 2011 at 8:54 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    I misread. Swapping in the LSD would probably be a pain. But if you want I will trade you your e-locker for an open diff that you can put an LSD in
  5. Oct 29, 2011 at 8:58 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Save your money op and keep the trd locker
  6. Oct 29, 2011 at 9:18 AM
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    Shit I will trade you my LSD rear end for your locked rear anyday
  7. Oct 29, 2011 at 4:57 PM
    RockRescue
    Oregon
    2007 TRD Sport
    the e locker is not tied into the computer . you can also get the wireing from 12 volt guy .com if you need to . it would be a straight forward swap . personaly i think you would be better off to keep the locker though .
  8. Oct 29, 2011 at 6:02 PM
    cummins6speed
    The e-locker is actually tied to the 4wd computer (unless its a prerunner) which is why you can't engage it unless you are in 4lo, but disconnecting it won't cause any error codes
  9. Oct 29, 2011 at 6:05 PM
    TacomaPrime
    Greg
    Illinois
    Mine is a prerunner
  10. Oct 29, 2011 at 6:27 PM
    RockRescue
    Oregon
    2007 TRD Sport
    the switch may be tied into the computer But the rear 3rd member ( the elocker itself ) is not . I have put them in my 85 and it has nothing to do with a computer . That is why i suggested useing a stand alone switch / harness from 12volt guy . so to answer the OP yes you can do the swap but you will have to swap the complete axle NOW with that said i have no clue if the newer lsd will work ? i think in 09 they changed
  11. Oct 29, 2011 at 6:48 PM
    PaidUpTruck
    PaidUpTruck Well-Known Member
    San Antonio, TX
    Tacoma TRD Off-Road 4x4
    Just because you don't go off-road, does not mean that you won't need it one of these days. Case in point, I went to the beach a few years back and while I kept to the paved road, a gal flagged me down because her BF got his truck stuck in the sands. I can see from a distance that he was rocking his F150 to no avail. Was not able to pull him out with 4Lo, had to lock the rear differential to get it done.
    Anyway, it's better to have it and not need it than to need it and don't have it!
  12. Oct 29, 2011 at 8:48 PM
    TacomaPrime
    Greg
    Illinois
    I probably will.
  13. Oct 29, 2011 at 8:48 PM
    TacomaPrime
    Greg
    Illinois
    I dont have 4x4 :(
