Swap TPMS or buy new
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lunartic, Nov 11, 2022.
  1. Nov 11, 2022 at 1:44 AM
    Lunartic
    Lunartic [OP] Well-Known Member
    New Jersey
    New wheels got delivered yesterday (Method 703's) and was wondering what the consensus was for the TPMS. Should I just swap the stock ones to the new wheels or just buy new and have the tire shop program them to the truck? If so, which ones are recommended?
    cammerv8 likes this.
  2. Nov 11, 2022 at 2:20 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    It all depends on what you want to do with wheel/tires you are replacing.
    Chew likes this.
  3. Nov 11, 2022 at 2:23 AM
    Lunartic
    New Jersey
    Do you mean if I plan on just selling them they're worth more to someone if the have the TPMS with them? More marketable not necessarily price wise?
  4. Nov 11, 2022 at 2:40 AM
    Martian__
    Martian__ Well-Known Member
    Southern California
    If u swap your old ones, a shop is going to charge u for it and you’ll be stuck with old sensors.
    If you buy new ones, you’ll have new sensors programmed and you can sell your stocks as a complete package for more money.
    To me it’s a no brainer, why spend money to swap old ones that usually last about 5 years or so. Keep the stock units as is just in case I want to swap the them back later or sell them for a little added money because they’re complete. New oem sensors can be bought from online Toyota sites just around $150 for 4. A tire shop will charge you at least $15 each for dismount and mount just to swap the sensors over.
    ScrippsRanch67 and skidooboy like this.
  5. Nov 11, 2022 at 2:42 AM
    OhNoItsMe
    OhNoItsMe Well-Known Member
    NM
    2022 TRD OR
    I ordered wheels/tires package with new TPMS. The truck is really shotty with the new sensors and only wants to read the pressure sometimes.. like maybe 10% of the time. Wish I would’ve had my OEM sensors swapped into them before I sold them.
  6. Nov 11, 2022 at 2:45 AM
    Lunartic
    New Jersey
    The truck has 1600 miles on it so they're not "old" but I understand what you're saying. Would you recommend just sticking with OEM sensors or aftermarket ones like Autel?
  7. Nov 11, 2022 at 2:53 AM
    Tacobela
    Tacobela New Member
    2017 SR5 4x4
    None...yet
    Stick with your OEM sensors, especially since they're practically new.
  8. Nov 11, 2022 at 3:04 AM
    BPfishing
    BPfishing Well-Known Member
    Brian
    Central Texas
    2019 Tacoma TRD OR
    At discount tire, swapping your TPMS sensors over is no extra charge.
    MadKatt, whatstcp and Lunartic[OP] like this.
  9. Nov 11, 2022 at 8:05 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    if you swap your sensors, do not remount the tires to the wheels. the person you sell them to will have to pay to have new sensors installed including unseating the tires to install new sensors. I cant understand why people remount the tires, after they remove the sensors, then try to sell them. makes no sense.
    with you being in New Jersey, I would keep the stock wheels and sensors, and use them in the winter. gives you 2 sets of wheels and tires to rotate, less tire wear on each set. and you get to save your good wheels for a lot longer time. Ski
    eurowner and Kllrbee like this.
  10. Nov 11, 2022 at 8:15 AM
    Kllrbee
    Kllrbee Well-Known Member
    Tim
    Bloomfield, WI
    22 Army Green DCSB Sport
    This is a great point.
    I see this alot and never understood it myself.
    Almost seems like a dickmove on the part of the seller...
    skidooboy[QUOTED] likes this.
  11. Nov 11, 2022 at 8:23 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    At least the wheels and tires can be used if they are mounted and can show they hold air. I put my old wheels and tires back on to ceramic coat my new wheels and give them a chance to dry before putting the new ones back on. The person I sold them to didn't care about the sensors since it was going on an older truck. I guess it depends on how you look at it. :notsure:
  12. Nov 11, 2022 at 12:01 PM
    BPfishing
    Brian
    Central Texas
    2019 Tacoma TRD OR
    I’d say most people buying takeoffs are buying them for older trucks without tpms.
    Regardless. I haven’t heard of a shop charging more than their standard tpms installation price just because they have to dismount a tire.
    That’s just part of the job.
  13. Nov 11, 2022 at 12:03 PM
    Lunartic
    New Jersey
    Thanks everyone. I'll talk to the tire shop next week.
  14. Nov 11, 2022 at 12:16 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Haha.. you don't have to buy them?
    I bought sensor-less OEM alloy wheels and tires that had 10 miles on them for $650. It was a great deal for me and apparently the seller. I don't really care about TPMS.. I walk around the truck and can see if they're inflated. If I get desperate I break out the old school tire pressure gauge.
    slipperypete and Kllrbee[QUOTED] like this.
  15. Nov 11, 2022 at 12:17 PM
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    when i got my 4R TRD pro wheels, Mavis just transfer the TPMS and put "service Kit" for the OEM sensors. the Service kit was new seals for the contract point.they did everything for 100 bucks. i did not wanted to pay for aftermarket tpms since people states they had issues with them
  16. Nov 11, 2022 at 2:06 PM
    Kllrbee
    Tim
    Bloomfield, WI
    Too much coffee today?
    Easy big fella...:D
    I get your point. Just found it a little bizarre of a practice..thats all.
  17. Nov 11, 2022 at 3:45 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    u r stuck dude !!!! i'll give you 2 fiddy to take those 703's off your hands:anonymous:
  18. Nov 11, 2022 at 3:50 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I’m on my original TPMS from 2013, I actually intended to replace with new OEM this time last year but wanted to see how far the current ones will run.
  19. Nov 11, 2022 at 4:52 PM
    Martian__
    Southern California
    That’s very impressive. Everyone should stick with OEM ones.
  20. Nov 11, 2022 at 5:14 PM
    Lunartic
    New Jersey
    $250 huh? I'll sleep on that offer....lol. Everyone has them on sale right now. About $50 bucks less per wheel and free shipping on Amazon.
    RIX TUX[QUOTED] likes this.
