Swap TPMS or not?
Discussion in 'Wheels & Tires' started by glwood6, Nov 3, 2009.
  1. Nov 3, 2009 at 8:40 AM
    glwood6
    glwood6 [OP] Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I recently got a set of 4Runner SR5 wheels to replace my stock steel wheels. They already have the TPMS sensors installed. Will the sensors already on the alloy wheels work on my truck, or do I need to swap out the sensors that I have on my steelies now?
    I plan to use the tires currently on my steel wheels, don't want to shell out the $$ for new tires just yet, so it's a matter of dismounting tires from stock wheels, remounting on alloys. Just wanted to get some input on the TPMS issue. Thanks.
  2. Nov 3, 2009 at 8:59 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if the sensors in your wheels now will fit into the other wheels ,swap them because your sensors are already programmed into the tpms unit,if you leave the other sensors in you will have to have them programmed at the deleo.
