Swap TRD Sport for TRD Off-Road Shocks/Springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChrisK7UND, Jan 8, 2019.
  1. Jan 8, 2019 at 9:29 AM
    ChrisK7UND
    ChrisK7UND [OP] Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    I have been contemplating this for some time. I have a 2017 TRD Sport, and I would like a bit softer ride. I see lots of TRD Off-Road Take-Offs locally on FB Marketplace or Craigslist. These include the front shocks/springs already assembled and the rear shocks. Has anybody done this? I assume it is an easy swap for the typical garage mechanic as you don't have to take the whole suspension apart. I would also assume an alignment for good measure would be in order. Any Sport people done this and then wished you kept your sport shocks? I drive mainly on highways and county roads here in Colorado, BUT, that being said, some of these county roads are an adventure on their own..... Thanks!
  2. Jan 8, 2019 at 9:31 AM
    fillsrunner4
    fillsrunner4 Active Member
    Fill
    Sammamish, Wa
    3rd gen Tacoma TRD Sport (Hers) 3rd gen 4Runner(Mine)
    I’d upgrade to the 5100s over stock used trds personally or go 6112s with 5160s in the rear. Just my two cents. The offroad will have a stiffer ride. The stiffer ride would be better all around because you would increase control. As for install it’s beyond easy and there are tons of videos on it
  3. Jan 8, 2019 at 9:38 AM
    ChrisK7UND
    Colorado
    My understanding, the SPORT has the Hitachi shocks, which are a stiffer "Sport-Tuned" shock vs. the Bilstein that the Off-Road uses. The Off-Road has a softer rebound for more off-road articulation properties over Sport-Tuned for Highway cornering etc. If I am wrong, I would be going even further backwards than what I have now if it would be stiffer.
    JJ Diablo, raptor2018 and shakerhood like this.
  4. Jan 8, 2019 at 9:42 AM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Unless they were very cheap I'd go with something like the guy selling you the shocks went with (better).
    TacomaSport86 likes this.
  5. Jan 8, 2019 at 9:45 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    This seems to be contradicting statements.
    fillsrunner4[QUOTED] likes this.
  6. Jan 8, 2019 at 10:25 AM
    fillsrunner4
    Fill
    Sammamish, Wa
    “It” was supposed to be “Not.” My phone changes those words for no reason lol. Just a typo
  7. Jan 8, 2019 at 10:27 AM
    fillsrunner4
    Fill
    Sammamish, Wa
    Honestly I would get some 5100s they are cheap and better then the sport and offroad shocks. Can do similar rear. The 5100s are also adjustable for leveling or mild lift if you ever wanted. For the price it’s a good option
  8. Jan 8, 2019 at 10:46 AM
    vuTron
    SF Bay Area
    OP, sounds like a reasonable proposition, especially if you can acquire some OR shocks at a good price. The other angle you may take is to get meatier tires (vs. "low profile" tires on Sport models)
    fillsrunner4 likes this.
  9. Jan 8, 2019 at 10:54 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I did it, and I'd do it again.
    It made the ride a bit more plush, no more teeth rattling. It won't carve corners as well as it did with the stock suspension, but does that really matter in a truck? The swap is easy with hand tools, but you will need a breaker bar and a good torque wrench.
    This video will help you when you swap out the front suspension:
    I made sure that none of the alignment marks moved, didn't bother with an alignment, and with over 10K miles since the swap, I have no unusual tire wear. I have rotated the tires once over that time.
  10. Jan 8, 2019 at 12:52 PM
    ChrisK7UND
    Colorado
    Thanks for the reply. I was hoping to get a reply from somebody that has done it. I have seen the complete Off-Road parts around here for $100.
  11. Jan 8, 2019 at 5:41 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    I've done it. Strange that people would steer you towards stiffer shocks when you asked for more ride comfort. The OR shocks and springs will do what you want. I personally don't notice any significant increase in wallowing or body roll. You should be able to get very low mileage front strut assemblies and rear shocks for $200-250. Thats a pretty damn cheap mod. I think it took me about an hour and a half from getting the truck up on stands to lowering it back down on the new suspension. Mine were basically brand new take offs. Think I paid $250ish shipped from ebay. Personally, I hope to keep seeing nearly new take-offs for the foreseeable future, since $200 every 80K miles keeps me on nice fresh suspension.
    If you asked about more plush at high speeds offroad, then I could see going with the upper spec Bilstiens. The OR shocks are probably too plush for big hits and end up blowing through to the stops.
    BTW...no alignment needed if you dont touch the LCA alignment bolts. I didn't touch them. Pretty sure I popped the UCA ball joints and that gave me enough room to fish the assemblies out.
    Don't do the final torque in the lower end of the strut until you lower the truck back down on to the wheels. No need jack the LCA like on the OME video.
    JJ Diablo and ChrisK7UND[OP] like this.
  12. Jan 8, 2019 at 6:17 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Factory Off Road has a softer ride, the Sport has the stiff ride.
    JJ Diablo, ChrisK7UND[OP] and bulalo like this.
  13. Jan 8, 2019 at 6:23 PM
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    I’ve been thinking about doing this when I hit 50k on the truck (around summer time). Are the Sport and OR springs the same?
  14. Jan 9, 2019 at 10:39 AM
    pjensen641
    Boone, IA
    Fronts are different. Its best to get the fronts as an assembly. The rear springs I believe are the same, or at least not different enough to mess with. Just swap the rear shocks.
    RBaptist[QUOTED] likes this.
  15. Jan 9, 2019 at 10:56 AM
    fillsrunner4
    Fill
    Sammamish, Wa
    That’s odd to me. Wife’s sport road like a Cadillac super soft and floaty. Can’t imagine it being softer than that
  16. Jan 9, 2019 at 11:03 AM
    shakerhood
    Southern Ohio
    The Sport is harsh and jittery over rough pavement, the OR is a bit more plush.
  17. Jan 9, 2019 at 1:32 PM
    oconnor
    oconnor Where am I?
    Midwest
    I'd heard that too going in and assumed it would ride like my GTI. Thankfully it is much plusher. So it depends somewhat on what vehicle you are coming from.
    shakerhood[QUOTED] likes this.
  18. Jan 9, 2019 at 1:47 PM
    shakerhood
    Southern Ohio
    Definitely when comparing to different style vehicles. It's always good for potential Tacoma owners to drive different models to see what works for them.
    oconnor[QUOTED] likes this.
  19. Jan 9, 2019 at 2:47 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    The OR will have a bit more nosedive on braking and while the OR shocks will certainly cushion the impacts from uneven pavement, it will come with quite a bit of travel in the truck itself. It will soften the ride but there will be bouncing and more side-to-side body role and whatnot. Overall I like the OR suspension for what it is - it really excels on moderate washboard at a bit of speed or gravel but still isn't terribly civilized on pavement IMHO.
    I resigned to get at least 40k out of the stock shocks before upgrading. Most likely will do a 6112/5160 swap in the next few months - will make it easier to get my wife to be OK with going offroad when we are in the mountains :)
    raptor2018 likes this.
  20. Jan 9, 2019 at 3:59 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I personally wouldn't do it. The 5100s made my sport ride a lot better, handles great, got some lift from the shocks.
