swaping cabs???
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, Feb 3, 2012.
  1. Feb 3, 2012 at 12:08 PM
    houndsmen
    houndsmen [OP] Well-Known Member
    My buddy rolled his 96 tacoma v6 standard, and is looking to purchase another parts pickup to swap the cab, fenders, etc.. But he had a good question that I couldnt answer. What years will fit his 96 and since his is manual would a cab from an automatic fit his manual?
  2. Feb 3, 2012 at 12:53 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    My guess is the cabs are the same as the clutch pedal and brake hangers are in stalled at the factory as required, same goes for the trans, call a salvage yard they have a interchange book and can tell for sure.
  3. Feb 3, 2012 at 12:54 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I swapped my cab out with a different one but that was on an 82. Fun stuff.
  4. Feb 3, 2012 at 12:54 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    you might have to cut the floor for the shifters but other than that should be a straight forward swap
  5. Feb 3, 2012 at 12:57 PM
    houndsmen
    Thanks guys!
  6. Feb 3, 2012 at 12:58 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you think so even with being a 96 going to like an 04? wouldnt it need to be 95.5-2000? or is it just the flares thats different on the cabs?
  7. Feb 3, 2012 at 1:29 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    i think the only difference between the cabs of a 96 and a 04 would be the interior :confused: but it should swap in with little modification
