Swaping out door handles on a 4th gen 4runner.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1stDueL22, Jun 24, 2017.
  1. Jun 24, 2017 at 5:34 PM
    1stDueL22
    1stDueL22 [OP] Well-Known Member
    Va. Beach, Virginia.
    2025 Bronze Oxide Off Road LB Premium
    Need some help here guys. I'm trying to swap out exterior chrome door handles with black ones on a 4runner and I am having a hard time with the drivers door. I got all the other doors done already but I can't seem to get the key lock mechanism out after loosening the #30 Torx screw.
    I have read that our tacos are the same as the 4runners so the write ups that I have seen both just say pull it out. Is it just that easy? It should just pull out? The one I'm playing with will not just pull out! I seem to think that something needs to be removed from the back/inside of the door before it will come out.
    Any advice you might have would be great. Thanks!
  2. Jun 26, 2017 at 3:50 PM
    1stDueL22
    Well after spraying some WD-40 and just playing (wiggling back and forth) with the lock for awhile, I was able to finally pull it out.
    So I write this encase some time in the future, someone else has this problem, they will learn that you just have to stay with it. :)
