Swapped Tires on Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cmar, Jan 3, 2020.
  1. Jan 3, 2020 at 12:33 PM
    Cmar
    Cmar [OP] Member
    Hello,
    Anyone swap tires and truck seems to wobble and not drive as smooth? Dealership can't find anything wrong. It's a 2019 Tacoma SR5 4x4
    These tires were on the truck before and rode very smooth.
    FishnTx likes this.
  2. Jan 3, 2020 at 12:36 PM
    tgarza74
    tgarza74 Well-Known Member
    Mario
    2016 SSM TRD OR
    OvTuned
    Need more info...
    dc2’s likes this.
  3. Jan 3, 2020 at 12:40 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Were the new tires balanced? If so, how much weight did each take?
  4. Jan 3, 2020 at 1:15 PM
    Cmar
    Cmar [OP] Member
    first time around one tire wasn't balanced.. brought it back and it was RR. i don't know how much each wheel took for weights. It still does not feel right
  5. Jan 3, 2020 at 1:18 PM
    Clearwater Bill
    Billy
    Largo Florida
    As you've posed the question, the answer can be yes or no.
    More detail about what's going on would be helpful.
  6. Jan 3, 2020 at 1:43 PM
    Cmar
    Cmar [OP] Member
    Alignment is good - frontend dead on straight. the truck used to glide and now it seems to vibrate up through seat as it did before the first tire was out of balance
    FishnTx likes this.
  7. Jan 3, 2020 at 2:06 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Make sure the lugnuts were installed correctly. Not sure about the 3gen but my 2gen made a difference in mine to make sure each one was snugged up (all 6)THEN start the star tightening pattern, then final torque with the wheels on the ground.
  8. Jan 3, 2020 at 2:08 PM
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    are they KO2s?
    Tocamo likes this.
  9. Jan 3, 2020 at 2:09 PM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    This is a good habit to get into, I do it anytime anyone other tan me works on my truck. Most dealers and tire places I know just give it a few ugga duggas and call it good.
    Edit: also, while we are on the topic, it's a good idea to check the lugs again after the first few hundred miles. They can and do come a little loose.
    MGtaco2.7[QUOTED] and FishnTx like this.
  10. Jan 3, 2020 at 2:10 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Does this mean that you did a Tire Rotation?
    Do another rotation to see if the problem goes away.
  11. Jan 3, 2020 at 2:21 PM
    Cmar
    Cmar [OP] Member
    I would sure hope a Toyota dealer with torque down the nuts correctly! I can only go by what they tell me.
    They said they moved tires around to see if it goes away and no difference.
    Thanks for the feedback.
  12. Jan 3, 2020 at 3:32 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What brand/model tire?
    PSI?
  13. Jan 3, 2020 at 4:22 PM
    Cmar
    Cmar [OP] Member
    OE Toyo A31 PSI 34 at around temp outside 40ish
