Swapping 1st gen Tacoma body on 4Runner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rushili, Aug 10, 2021.
  1. Jul 6, 2022 at 4:56 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    he could put the cab and the tail lights, and just not have a bed...
  2. Jul 7, 2022 at 6:10 AM
    906-Runner
    906-Runner wants to be a race car driver
    Yooper Peninsula
    The cool thing to do would be take the manual transmission from your rusty Taco, swap it into the 4Runner and call it a day. Swap the Tacoma front clip; headlights, grille, hood, fenders, bumper, etc. onto the 4Runner as well. Then you’d have one badass rig
  3. Jul 7, 2022 at 7:22 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Without some good Fabrication skills the equipment and a place to work.
    Anything but a direct replacement frame will be beyond your skills at this time.
    Being it is a 1997 that it lasted this long is real good.
  4. Jan 21, 2023 at 9:23 AM
    Jowerd
    Jowerd New Member
    Joey
    5th tacoma 6th 4runner
    All of them
    I recently put a 1997 regular cab tacoma ona 2000 4 runner. I just did a complete swap. I had to use the complete 4 runner harness, hvac box, pcm, ignition, cluster, column, basically the complete dash. Also had to move the rear cab mounts back about 2 inches. The front 4 cab mounts line up (2 left 2 right). None of the bed mounts line up. There is a 2 in difference in wheel base. I'm going to use that 2 inches between the cab and the bed to hide in a roll bar... the rear suspension is completely different, but the center chunk is the same, so if you have a locker, or gearing upgrades, that can be swapped easily. The rear is a 4 link. And if you know anything about 4 pinks vs leaf springs you know the 4 link is a way better design. Much more wheel travel side to side. It can be done. You do need a welder, but the cab mounts are easy compared to figuring out the dash...
  5. Jan 21, 2023 at 10:26 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Cant just tell us.......you have to show us........
    ......or it never happen........
    you could be a legend....
    Tacoma Cross Over pre-VVT..... is born........
    .......when do you start taking orders........
    Taco critter likes this.
  6. Jan 21, 2023 at 7:26 PM
    Bivouac
    What was your reason for changing the cab harness? A stripped bare bones cab?
    Did you start with a 4Runner Rolling Chassis and complete drive train?
